Home > Technical > Why don't the front swivels have a rubber gaiter/cover?
Norm4n
They get covered in crap and wear out!
Post #204112 21st Jan 2013 10:47pm
Tiger
If they had a cover it would fill with crap and they would wear out faster.
Early 90 / 110 did have them
I think series had leather ones
Post #204116 21st Jan 2013 10:55pm
ibexman
The later ones are supposedly Teflon coated Whistle Whistle
Post #204118 21st Jan 2013 10:57pm
Because, on the whole, they're more trouble than they're worth. They're very exposed and so easily damaged. The slightest bit of damage lets water in, which is then held against the swivels causing rust and they wear out even quicker.
They also make it more difficult to detect leaking seals, although that's less of an issue with the grease used these days. Darren
Post #204120 21st Jan 2013 10:57pm
Happyoldgit
There used to be a company that produced rubber gaiters to fit over the swivels but as has already been stated they and their leather, laced up counterparts tend not to be 100% waterproof and so trap moisture and muck. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #204275 22nd Jan 2013 1:19pm
I used to have the leather gaiters on my old 90 (I've got the pert numbers at home if you want them) but As was said above, they get a slight tear in them (which you don't notice), then after a while the seals start to leak.... so you remove the leather gaiter and find it full of silt and stones....
ask me how I know.... so i binned them.
Post #204288 22nd Jan 2013 1:47pm
