![]() | Home > My Defender > The FCX Defender 130 build thread |
Hi Ray,
The foam was bought from Acefoam: 1 off 2000mm x 2000mm x 40mm Eggbox Style Acoustic Foam with Self Adhesive backing £53.50 each All Quotes include VAT and Parcelforce delivery ( orders placed before 3PM will be despatched that day) Our sales team will offer advice on foam products call 01952 581267 Hope that helps ![]() |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 ![]() ![]() ![]() |
Great job you've done on that Matt
![]() Ive just finished mine (if it is ever really finished), and if it helps, found 12mm flat closed cell foam (I used foil faced foam in the hot areas) fits nicely under the rubber transmission tunnel mat and inside the doors - any thicker and it gets hard to form around the curves. |
Excellent ![]() Keep up the good work, yours is looking mint!! Ray |
Thanks guys
What are you currently working on on the 130 now Matt?
![]() ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Hi Steve,
I've nearly finished the rear seat box, cut three holes in it to set two amps in and a plastic storage box and then covered the whole lot in Dynamat and then carpet - Pics to follow .... |
Look forward to it! With your tailoring skills I don't doubt it'll be a top notch job. ![]() ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Thank you
BjornAgain Member Since: 29 Oct 2012 Location: Johannesburg, South Africa Posts: 22 ![]() ![]() ![]() |
Interested to know why you put the egg box style acoustic foam on the roof and the dynamat elsewhere...? Apart from cost why not put the dynamat on the roof as well...? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Hi BjornAgain,
It wasn't a cost reason. I wasn't convinced that the Dynamat would stay glued to the ceiling and if it 'fell' off would be heavy on the headlining. Time will tell if the foam will be just as effective in it's sound deadening properties... |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
i thought dynamat glued/sticks really well? your 130 is coming on nicely, like it. |
Thanks Chadjizz
![]() Yes, actually now I've used it on the floor it does stick fine. I don't think I'll be able to tell the difference between that and the foam on the ceiling acoustically though. |
anything is going to be an imporvment any way. i need to kit my 130 out with some. i have taken the rear seats and box out and its even more load now!
![]() My rear seat box has a few holes in now ... ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
