![]() | Home > Puma (Tdci) > Alarm/remote range now non-existent |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Two possibilities spring to mind.
Flat/cold batteries in key fob. Cold weather causing the door mechanism just to catch on the door card etc. Would try new batteries in key fob first. Brendan |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
But, follow the instructions for changing the battery in key fob - carefully. LANDYWATCH
![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
I've noticed reduced range on mine but nothing much. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18033 ![]() ![]() ![]() |
Another possibility is a local source of EMI or RFI (electromagnetic or radio frequency interference). I had a similar problem a few years ago which was almost certainly due to a local TETRA cell malfunctioning. If this is the case the effect will be very localised. If it happens everywhere it will be the handset batteries.
Mote Member Since: 07 Sep 2012 Location: Cardiff Posts: 8 ![]() ![]() ![]() |
OK, I probably didn't explain well enough to be honest.
No problems with the door mechanisms at all, I could gain access with the key itself, no problem. But when trying to open the vehicle with the remote, nothing. No indicators, no unlocking. I tried both remotes (one rarely used) but both didn't work. The fob would, however, set/unset the alarm if I held it within 6 inches of the AS10 unit. I've since taken a closer look at the AS10 unit (the green box) and I think the problem was corrosion on the connections in the connection block that the antenna comes from. A bit of switch cleaner on the connections seems to have solved the issue. Let's hope so anyway, and hope it's not something like a dry solder joint or similar inside the unit (because it looks really difficult to get out)... Cheers all. |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
And put back in! Had to cut a few holes to get screws back in. Think they put the AS10 in first and then build the car around it. Merlin |
