Home > Puma (Tdci) > Alarm/remote range now non-existent
Mote
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
Has anyone had a similar issue...
Tried to open the defender today and neither fob would open the car. Used the key to get in setting off the alarm then tried the key again and it worked. Basically it only works within about 6 inches of the receiver (the little green box up behind the speaker).
I checked the connection of the antenna to the box and that seems fine, so I'm thinking there's a break inside the green box. Has anyone had a similar issue before I try taking that unit out and taking a look?
Post #202822 18th Jan 2013 10:09am
leeds
Two possibilities spring to mind.
Flat/cold batteries in key fob.
Cold weather causing the door mechanism just to catch on the door card etc.
Would try new batteries in key fob first.
Brendan
Post #202824 18th Jan 2013 10:15am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
But, follow the instructions for changing the battery in key fob - carefully. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #202833 18th Jan 2013 10:42am
I've noticed reduced range on mine but nothing much. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #202844 18th Jan 2013 10:56am
Another possibility is a local source of EMI or RFI (electromagnetic or radio frequency interference). I had a similar problem a few years ago which was almost certainly due to a local TETRA cell malfunctioning. If this is the case the effect will be very localised. If it happens everywhere it will be the handset batteries.
Post #202848 18th Jan 2013 11:06am
Mote
OK, I probably didn't explain well enough to be honest.
No problems with the door mechanisms at all, I could gain access with the key itself, no problem. But when trying to open the vehicle with the remote, nothing. No indicators, no unlocking. I tried both remotes (one rarely used) but both didn't work. The fob would, however, set/unset the alarm if I held it within 6 inches of the AS10 unit.
I've since taken a closer look at the AS10 unit (the green box) and I think the problem was corrosion on the connections in the connection block that the antenna comes from. A bit of switch cleaner on the connections seems to have solved the issue.
Let's hope so anyway, and hope it's not something like a dry solder joint or similar inside the unit (because it looks really difficult to get out)...
Cheers all.
Post #202875 18th Jan 2013 12:25pm
Merlin
And put back in! Had to cut a few holes to get screws back in. Think they put the AS10 in first and then build the car around it.
Merlin
Post #202942 18th Jan 2013 2:19pm
Mote
Smile you're not wrong. I think I'd resort to a strong double sided tape and hope to never see it again.
Post #202954 18th Jan 2013 2:49pm
