![]() | Home > Maintenance & Modifications > LED Interior Festune |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
Hi geobloke,
I've had those on my 90 for the past 5 months after having some poor results from some similar ones bought on eBay ( they lost LEDs over a few weeks. However the Amazon ones have stood the test of time and have not lost any LEDs. Very bright and very useful.
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Good to know Welshgas |
| appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630
If I fitted those aforementioned LEDS to my TD5, the soft start function wouldn't work, would it ?
If you mean the gradual brightening and darkening then yes they do work, but are a bit steppy rather than a smooth act. |
Ah, thats good. Thanks
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Click image to enlarge Click image to enlarge 38mm Do indeed fit but from fitting I think standard is 36mm bulbs. As the pins need slightly adjusting to take a 38mm. 0.1w draw 11w output on these. Standard bulbs are 10w draw and output. Is a bit darker being red but I prefer that than being lit up white like a football ground at night and it's much softer on the eyes. Also don't have the worry of leaving doors open and battery drain now. as basically as I do that a lot before I had them pretty much off all the time. Now with these they are on when the doors open. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
mhmmmmm Steve........
Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
How does that work then? If they were 0.1A consumption (assuming 0.1W is a typo), that would equate to 1.2W. If they were 11W that would be 0.9A? Changing them for red ones must alter the laws of physics. Pete |
dgardel -
XS Pete - That was what I thought I read somewhere but I'm probably wrong then. (on hindsight can't remember where either) My mistake. They are these: http://www.autobulbsdirect.co.uk/272-LED-F...lours.html Two reviews on them both 5star. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Ok I understand now. Their description says <1W which makes much more sense. To have been 11W they'd have needed a couple of 5W Crees in and then you'd have to drive about wearing welding goggles.
Pete |
"Designed with the latest LED technology the 272 will help to improve longer life up to 50,000 hours, improve durability and require less power consumption at less than 1W!! "
That was where I read it. ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
Looking good Steve
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
GUM - Cheers. Will try and take a photo tonight if I don't get frozen in the process.
Best photo I can come up with is this. Camera is only a phone one and seems to hate the light levels and colour so makes it look MUCH darker than what it really is. (you'll have to take my word for it)
Click image to enlarge ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| All times are GMT |
