![]() | Home > Maintenance & Modifications > LED Interior Festune |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Hi geobloke,
I've had those on my 90 for the past 5 months after having some poor results from some similar ones bought on eBay ( they lost LEDs over a few weeks. However the Amazon ones have stood the test of time and have not lost any LEDs. Very bright and very useful. ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Good to know Welshgas ![]() |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
If I fitted those aforementioned LEDS to my TD5, the soft start function wouldn't work, would it ?
If you mean the gradual brightening and darkening then yes they do work, but are a bit steppy rather than a smooth act. |
Ah, thats good. Thanks
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20975 ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() 38mm Do indeed fit but from fitting I think standard is 36mm bulbs. As the pins need slightly adjusting to take a 38mm. 0.1w draw 11w output on these. Standard bulbs are 10w draw and output. Is a bit darker being red but I prefer that than being lit up white like a football ground at night and it's much softer on the eyes. Also don't have the worry of leaving doors open and battery drain now. as basically as I do that a lot before I had them pretty much off all the time. Now with these they are on when the doors open. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
mhmmmmm Steve........
![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
How does that work then? If they were 0.1A consumption (assuming 0.1W is a typo), that would equate to 1.2W. If they were 11W that would be 0.9A? Changing them for red ones must alter the laws of physics. Pete |
dgardel -
![]() XS Pete - That was what I thought I read somewhere but I'm probably wrong then. (on hindsight can't remember where either) My mistake. They are these: http://www.autobulbsdirect.co.uk/272-LED-F...lours.html Two reviews on them both 5star. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Ok I understand now. Their description says <1W which makes much more sense. To have been 11W they'd have needed a couple of 5W Crees in and then you'd have to drive about wearing welding goggles.
Pete |
"Designed with the latest LED technology the 272 will help to improve longer life up to 50,000 hours, improve durability and require less power consumption at less than 1W!! "
That was where I read it. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Looking good Steve
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
GUM - Cheers. Will try and take a photo tonight if I don't get frozen in the process.
Best photo I can come up with is this. Camera is only a phone one and seems to hate the light levels and colour so makes it look MUCH darker than what it really is. (you'll have to take my word for it)
![]() Click image to enlarge ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
