Home > Maintenance & Modifications > Questions: XS Drivers Seat Re-Trim
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Usual issue - side bolster flat, sticks in back a little, looking tired.
I have fitted new covers only previosuly following damage by the stealership so got the hog ring pliers etc.... but a few questions;
1. The base & back self adhesive heat pads - is it possible to remove these and refit? (they are �60 each). If so, are people fixing using the upholstery glue or .....
2. The Exmoor Trim XS kit - does it match the original LR trim in the rest of the cab? (Are they oem? Do they make the original ones for LR?)
Have priced up the genuine parts off Microcat and your looking at a sweet penny going genuine Rolling Eyes
Cheers lads!
Post #198979 4th Jan 2013 7:20pm
JeremyJ
What year is your xs? Late td5 (06my on I think) is slightly different to earlier xs trim.
I used a complete Exmoor back on mine, matched fine
Post #199007 4th Jan 2013 9:04pm
Killer90
Site Sponsor
yer is a lot different, in trim Thumbs Up the exmoor trim is a really good match but comes with exmoor tag sowed on Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #199020 4th Jan 2013 9:27pm
JeremyJ
You sure? Mine was the seat back as a repair section - no tag.
I know their complete seats do though
Post #199022 4th Jan 2013 9:30pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Re: Questions: XS Drivers Seat Re-Trim
sorry to hijack the thread, but happened to me yesterday...I was fitting the radio and leaned to the back seat to get a tool and it happened this....
can't this be fixed? Is the only option to re-trim the seat? Shocked ...I'm out of warranty allready ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #199259 5th Jan 2013 8:57pm
JSG
Same thing happened to mine. The foam is not as well made as it could be. I had a new seat fitted under warranty but I expect the new one to go the same before too long. John
2011 Tdci 110 CSW XS
Post #199267 5th Jan 2013 9:11pm
Fifth Horseman
Mine went like that as well, got a replacement foam from Exmoor Trim and refitted the cover.
I had the same concerns with the heater pad but managed to re-attach it with spray glue.
Post #202234 15th Jan 2013 10:02pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Best repair is to replace the entire foam.
Real world - I did exactly the same once, and managed to remove the cover, pull the foam back to where it was supposed to be, and sprayed a bit of contact adhesive in the tear. Still going strong now.
Post #202238 15th Jan 2013 10:07pm
lrmaniac
I've managed to bring it back to place, but it goes flat again...
How can I remove the cover and try to fix it? There's a plastic zip on the bottom but can't see a way to unzip it without damaging it... Sad ? Any help? Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #202590 17th Jan 2013 4:09pm
Fifth Horseman
The 'zip' is just two interlocking pieces of plastic, they should pull apart with the right persuasion - not easy with todays temperatures.
Post #202593 17th Jan 2013 4:16pm
appaloosadude
OP is in Portugal... Don't think he'll have the temperature issues we've got...
Post #202595 17th Jan 2013 4:17pm
Fifth Horseman
doh Embarassed
Post #202596 17th Jan 2013 4:19pm
lrmaniac
Ok...I thought that you had to slide them apart...I'll try the "pull" version! Will it be easy to refit then?
btw, It's not hot here...It's 9�C Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #202603 17th Jan 2013 4:56pm
appaloosadude
Oops...
Well, I know where I won't be going for some sunshine and warmth!
Post #202610 17th Jan 2013 5:12pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
. Just go on YouTube exmore trim seat retrim and they have a video on how to do it NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #202612 17th Jan 2013 5:22pm
