![]() | Home > Maintenance & Modifications > Questions: XS Drivers Seat Re-Trim |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
What year is your xs? Late td5 (06my on I think) is slightly different to earlier xs trim.
I used a complete Exmoor back on mine, matched fine |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
yer is a lot different, in trim ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
You sure? Mine was the seat back as a repair section - no tag.
I know their complete seats do though |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
sorry to hijack the thread, but happened to me yesterday...I was fitting the radio and leaned to the back seat to get a tool and it happened this.... ![]() Click image to enlarge can't this be fixed? Is the only option to re-trim the seat? ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. Last edited by lrmaniac on 5th Jan 2013 9:12pm. Edited 1 time in total |
Same thing happened to mine. The foam is not as well made as it could be. I had a new seat fitted under warranty but I expect the new one to go the same before too long. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 337 ![]() ![]() ![]() |
Mine went like that as well, got a replacement foam from Exmoor Trim and refitted the cover.
I had the same concerns with the heater pad but managed to re-attach it with spray glue. |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Best repair is to replace the entire foam. Real world - I did exactly the same once, and managed to remove the cover, pull the foam back to where it was supposed to be, and sprayed a bit of contact adhesive in the tear. Still going strong now. |
I've managed to bring it back to place, but it goes flat again... How can I remove the cover and try to fix it? There's a plastic zip on the bottom but can't see a way to unzip it without damaging it... ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
The 'zip' is just two interlocking pieces of plastic, they should pull apart with the right persuasion - not easy with todays temperatures.
OP is in Portugal... Don't think he'll have the temperature issues we've got...
doh
Ok...I thought that you had to slide them apart...I'll try the "pull" version! Will it be easy to refit then? btw, It's not hot here...It's 9ºC Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
Oops...
Well, I know where I won't be going for some sunshine and warmth! |
. Just go on YouTube exmore trim seat retrim and they have a video on how to do it NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
