Home > Td5 > Just got a TD5 defender, couple of potentially daft question
EMPI748
Scotland 2000 Defender 90 Td5 SW Baltic Blue
Just bought a TD5 defender 90, pic below...
Want to swap the middle seat for a cubby box, is it a straight swap, unbolt seat and bolt in box? Is there anything under the middle seat?
Also potential really daft one, is there anything under the rear seats or just lots of arch room, been under it a few times but not clocked on... Embarassed
Stu
Post #199815 7th Jan 2013 10:23pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
Some one wiser than me will come along in a minute but I THINK
Yes seat to cubby box is a straight swap. Not sure whats underneath it.
Yes again on the rear seats, lots of arch room for wheel travel etc.
Nice looking looking 90 Thumbs Up Strong people are harder to kill and generally more useful!
Post #199818 7th Jan 2013 10:28pm
excossack
On my 1999 110 there is a plate under the middle seat that allow access to the transfer case etc below. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #199819 7th Jan 2013 10:37pm
RRUK
When I removed the centre seat in mine to replace with a Paddock's sourced cubby box I found it didn't fit so well.
When the seat is removed you'll find a metal plate with a few screws, undo those and you get access to the top of the tranfser box. I thought the cubby box was supposed to slot into this rectangular hole but it didn't.
So I mounted mine on a plinth of plywood cut to size to squeeze in between the seats rails either side. I sprayed it black to blend in and it adds some weight so I don;t feel the need to bolt it in, which means I can remove it for when I need to do work etc. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #199822 7th Jan 2013 10:39pm
EMPI748
Perfect thanks for the help!
Does that mean that you have to remove the plate to use it or is the ply screwed to it? Next job is sound insulation, so might be a good while your there moment...
Now time to go cubby box shopping.
Post #199839 7th Jan 2013 11:29pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
The plate stays in place, the cubby bolts through it.
If you're not after an original cubby, Mobile Storage Systems do a very nice one.
Tony
Post #199869 8th Jan 2013 8:35am
We have an alternative design of cubby box available to the MSS one
Post #199873 8th Jan 2013 9:23am
On my Puma the cubby (originally centre tray) is secured to Rivnuts fitted to the metal plate.
Post #199884 8th Jan 2013 10:16am
There is no continuity with Land Rover, you may remove your centre seat and find four rivnuts already fitted underneath ready to accept a new cubby box alternatively there maybe just a blank plate.
We have found that the rivnuts aren't always in the same place from vehicle to vehicle and of course the previous owner may have made 'modifications'
We supply four rivnuts and a rivnut fitting tool with our cubby boxes to cover every eventuality
Post #199886 8th Jan 2013 10:31am
jst
in the past i have fitted cubby boxes by removing middle seat, removing the black metal access plate. attaching two runners to the metal plate (usually bolted to it with sunken heads). you can then refit the black plate (with runners on) and then attach the cubby to the runners using what ever spacers/raisers you needs to suit arm position!
wrt the rear arches, drivers side rear will have the fuel filler in part of it, the rest of it is open space. if you were looking to utilise that space the space to the front of the axle can be used by check axle movements/wheel rub/contact and allow for possible rim/tyre option changes! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #199898 8th Jan 2013 12:05pm
EMPI748
Thanks again, some great info!
Post #200410 9th Jan 2013 10:44pm
RRUK
I've done all manner of things to mine, including sound insulation. Feel free to make a cuppa, put your feet up and take a long read!
http://www.defender2.net/forum/topic10705.html 2016 D4 HSE
Post #200431 10th Jan 2013 12:11am
