![]() | Home > Maintenance & Modifications > Fitting a tow bar..... |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
Mine are not threaded. My bolts pass through hole and have washer and nut on the back.
Mine is a Td5 90. Andy |
| strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1405
OK - thanks. As I said the fitting guide (which appears to be genuine Land Rover) which I downloaded specifies an M12/35mm bolt - which won't fit through that hole size as it stands, and also makes no mention of nuts and washers either? Euro-Leafing to infinity and beyond.....
| williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441
had to drill mine out to 12mm.easy though
Did you tap the whole then or fit nuts and bolt? Euro-Leafing to infinity and beyond..... |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
use a nut and bolt, larger purchase area. Cheers
Yep nuts and bolts, preferably nyloc nuts.fit and forget
| All times are GMT |
