Home > Maintenance & Modifications > Fitting a tow bar.....
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
....should be the easiest thing in the world, but.....
Should the holes in the brackets either side of the fuel tank be threaded - or do I need to tap them out?
The inside of the small hole in the photo is not threaded? I would have thought it should be, as the instructions I downloaded from the tinternet specify an M12x34mm bolt to use here? so that I can fit the arms as shown below
Any ideas please Bow down Euro-Leafing to infinity and beyond.....
Post #199410 6th Jan 2013 2:53pm
landy andy
Mine are not threaded. My bolts pass through hole and have washer and nut on the back.
Mine is a Td5 90.
Andy
Post #199415 6th Jan 2013 3:23pm
strang
OK - thanks. As I said the fitting guide (which appears to be genuine Land Rover) which I downloaded specifies an M12/35mm bolt - which won't fit through that hole size as it stands, and also makes no mention of nuts and washers either? Euro-Leafing to infinity and beyond.....
Post #199472 6th Jan 2013 6:08pm
williamthedog
had to drill mine out to 12mm.easy though Wink
Post #199658 7th Jan 2013 12:27pm
strang
Did you tap the whole then or fit nuts and bolt? Euro-Leafing to infinity and beyond.....
Post #199665 7th Jan 2013 12:44pm
jst
use a nut and bolt, larger purchase area. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #199696 7th Jan 2013 2:13pm
williamthedog
Yep nuts and bolts, preferably nyloc nuts.fit and forget Very Happy
Post #199708 7th Jan 2013 4:06pm
