Home > Puma (Tdci) > mantec snorkel
williamthedog
mantec snorkel
just got a mantec snorkel.Instructions say you need a riv-nut tool.Is there any other way of attaching it without it,or improvising another way ?
Post #199013 4th Jan 2013 8:14pm
ZeDefender
I mounted one of these RAIs with rivnuts. Suppose you could try using nuts behind the panel but you only need to insert 2 rivnuts - make your own tool?
http://www.defender2.net/forum/topic8631.html Tell someone you love them today because life is short.
Post #199038 4th Jan 2013 8:44pm
williamthedog
Ok will try it.Just goes against the grain drilling into the wing and not knowing if homemade tool will work as i havent got any spare rivnuts Confused
Post #199043 4th Jan 2013 8:56pm
ZeDefender
No sweat - rivnuts are cheap off eBay and if you cock up they are easy to drill out and try again without any further damage - believe me, I know Whistle
Just remember - "measure twice, drill once" Thumbs Up
p.s. Many on here would also make the seal airtight with Sikaflex. I used butyl tape but I'm... "unusual" Laughing Tell someone you love them today because life is short.
Post #199054 4th Jan 2013 9:09pm
Pm your address I'll sendup some if required Thumbs Up
Are they M6 or M8?
Post #199055 4th Jan 2013 9:09pm
ZeDefender
You see - no problem Thumbs Up Tell someone you love them today because life is short.
Post #199056 4th Jan 2013 9:13pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Tip - put masking tape along the seam between the inner and outer wings when drilling the holes in the windscreen surround, as bits of swarf can get in the gap, and can be near impossible to get out again. Euro-Leafing to infinity and beyond.....
Post #199075 4th Jan 2013 9:46pm
williamthedog
How thIck is the ally window pillar anyway ?
Post #199078 4th Jan 2013 9:55pm
AndrewS
Post #199104 4th Jan 2013 11:25pm
Happyoldgit
Thick enough to take the self tappers that hold the bracket but do remove the interior screen trim [2 x self tapping screws] and pull the wiring that runs up under the trim out of the way before you drill the holes for the RAI support. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #199132 5th Jan 2013 8:56am
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I drilled a smaller hole and used a screw thread cutting tool to tap the holes.
Post #199506 6th Jan 2013 7:19pm
Jensen
France
Is there not also water drain off hole to block off inside the wing ?
Nearly trashed my 200tdi going through a ford water over the bonnet because it was'nt Shocked
Post #199544 6th Jan 2013 8:25pm
ZeDefender
Me too (mine was s/hand without bolts). I also coated the threads with Duralac to prevent bimetallic corrosion and seated the bracket with butyl to make it all watertight Mr. Green
@Jensen - I'm no wader but (at least in Pumas) there is a hole at the bottom of the airfilter box and one under the fresh air intake duct... Tell someone you love them today because life is short.
Post #199545 6th Jan 2013 8:28pm
Jensen
France
ZeDefender wrote:
They need blocking then if you fit a snorkel .
Post #199552 6th Jan 2013 8:53pm
Agree that's a good idea but if you have access to the rear, then why not fit ordinary bolts and nuts rather than rather ugly self tappers?
Post #199563 6th Jan 2013 9:09pm
