Home > Maintenance & Modifications > Defender thermometer?
Page 2 of 2 <12
MartinK
I've got the CheckTemp II - great bit of kit, and instructions here http://www.defender2.net/forum/topic5492.html
Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #199333 6th Jan 2013 9:25am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Heres a picture of my temperature sensor:
Seen as we all run about with our windows down and elbow out
If your arm goes a blue colour its cold.
If it turns red it's sunny.
If its wet its raining.
 Original Member Pie n Pea Club.
110 HCPU Tipper
Post #199338 6th Jan 2013 10:43am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
I've got a Check Temp too. It's got two temp sensors, one for outside, one for in. Fairly easy to fit but needed to experiment with where to put the sensors. I ended up with the inside one on the cubby box and the outside one on the headlight mounting panel - seems to work well. I don't understand why Land Rover don't fit a temp gauge as standard, the irritating thing is that I'm fairly sure the display is already there in the instrument binnacle if you could work out how to power it.
Post #199339 6th Jan 2013 10:46am
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
Got the check temp installed as well. The inside sensor behind the A pillar cover, slightly sticking out at the top. The outside sensor I put inside the tube of the raised air intake. After experimenting it seems to be a kind fo showing the true temperature, other places on the center console, the heater air intake, behind the bumper are pretty much influenced be the heating or aircon, engine and street heat.
Post #199373 6th Jan 2013 1:22pm
Kraut
Germany 2010 Defender 110 Puma 2.4 SW Santorini Black
My dealer fitted a VDO thermometer into the dash instead of the original clock, identical measurements. Costs were € 125,- for the item itself and appr. 100,- for fitting (again the limited knowledge when it comes to electronics....)
http://www.matzker.de/Technik-Zubehoer/fue...:3531.html
Post #199588 6th Jan 2013 10:59pm
dgardel
Italy
Is the same that sell by Mobilecentre
External sensor
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #199638 7th Jan 2013 11:09am
Page 2 of 2 <12
