![]() | Home > Maintenance & Modifications > Defender thermometer? |
| Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377
Mobile Centre do the Check Temp .
Looks like a nice piece of kit. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
That is nice. That was the sort of thing I was looking for but couldn't find.
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
It does look nice, I do want one but haven't been able to justify the cost yet so have one of these for now.
Works well, but isn't backlit and doesn't look as smart... |
Yes, the mobile centre one does look smart if a little expensive (You get what you pay for) My issue was I was looking on E-bay and it's mostly Chinese rubbish on there. ____\We|Will|Win/___
| v40mav Member Since: 25 Aug 2008 Location: UK Posts: 206
These look good. Not cheap but I do miss not having one in the defender.
Anyone fitted one to their defender. Keen to see an install and where the sensors need to be put Defender 110 County SW Disco 3 HSE Freelander 2 HSE - SOLD going back to a car www.lothian4x4response.org |
Hopefully some one will have one. ____\We|Will|Win/___
| lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764
dgardel has one on his defender....not sure if it is exactly the same, but it's very similar...search for his posts
edit: check this thread....it's on it...don't know where the original thread is http://www.defender2.net/forum/topic3998.h...ture+gauge Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. Last edited by lrmaniac on 5th Jan 2013 10:15pm. Edited 1 time in total |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
For a cheap one, I was looking at http://www.ebay.co.uk/itm/In-Car-Digital-A...1e7024079a 1999 Defender TD5 110
^^^ I saw that too earlier but one thing concerned me and that was where to put it without it getting in the way. If it got in the way too much chances are I'd never use it then as it'd get annoying. ____\We|Will|Win/___
Maybe above the rear view mirror, where the ash tray is on the dash (assuming you have a TD5), or over to the right above the dash binnacle? 1999 Defender TD5 110
Puma for me so you probably have more room. ____\We|Will|Win/___
To be fair I had a similar one in my TD5 and always thought it looked a bit cheap and nasty and really out of place. It was also really sensitive to voltage changes, resetting itself if there was a surge of any kind such as using the winch.
The check temp looks much more OE when installed The other one I linked to looks OK in a puma on the blank side panel next to the centre dash but had to be placed carefully to avoid showing the cable (i wont be keeping it long term but replacing it with a check temp when funds allow so didn't want to drill any holes). |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
I have one from Mobile Centre that I'm building in to the FCX 130, I'll update once its installed
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
i have fitted an UltraGauge (Brian/ Lorryman100) has written a great write up, this can display upto 7 screens of information and reset any fault codes etc and shows the airbox temperature.
see http://www.defender2.net/forum/topic11426....ltra+gauge |
| All times are GMT |
