Home > Td5 > Speedo goes mad..
Gareth
Speedo goes mad..
When I first start up my TD5, the speedometer needle shoots up to about 70mph, despite me not going anywhere! It soon returns to normal, and works normally and drives fine.
Any ideas? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #197176 29th Dec 2012 10:08am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Had the same thing intermittently. No idea what causes it!
Post #197178 29th Dec 2012 10:14am
landy andy
Try running new earth direct from battery to ECU mount, and possibly to bulkhead.
Andy
Post #197190 29th Dec 2012 10:58am
jst
mine did this, issue was water ingress into the 3 wire connector to the sender on the T box. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #197193 29th Dec 2012 11:08am
Green Machine
Mine did it once a few weeks back too - quite plausible that was water, we had a lot of it at the time! As an aside - does any one else's Td5 fuel gauge drop to zero then come back up again on startup? Noticed mine does it, but not sure if it always has done. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #197201 29th Dec 2012 11:43am
bob neville
Sometimes my fuel gauge drops to zero on start up. Probably 1 in 20 or 30 starts.
2013 Defender 90 CSW - sold
Post #197206 29th Dec 2012 12:22pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Weak battery. Change a new fresh battery fully charged and it goes away. I've had this on my 90 n a friend's 110 whose battery was on the way out. This is followed by the fuel gauge dropping to empty before returning to where it should be after starting. The defender has migrated, leaving the owner behind.
Post #197246 29th Dec 2012 3:31pm
bob neville
Thanks Achuakh Thumbs Up
I think my battery is 10 years old Shocked
I have a new one here already charged and ready to fit when it stops raining.
Post #197248 29th Dec 2012 4:10pm
