![]() | Home > Maintenance & Modifications > Fitting rear seat in Puma 90 hard top |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Standard centre seat won't fit ... doesn't clear the transfer box lever on Puma's
Now that sounds like a perfect idea! I'm off to search for d4 seats
rosscomax Member Since: 07 Nov 2010 Location: Fochabers Posts: 12 ![]() ![]() ![]() |
Hi, I managed to fit one no problem, I fitted 10mm spacers between the rails and the seat box (front only) then shortned the transfer box linkage, I am sure this was not ot much problem, think I only had to adjust the rod end on the linkage. |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Picture would be good please.. |
I have taken it out, and removed the bulkhead now I have rear seats (fitted a bulkhead removal bar) To allow kids access from front. I will have a look through my pics on my home PC. when I get back on dry land (stuck offshore for Xmas) on see if there is any pics, failing that I will do a quick drawing of where to fit the spacers and how to adjust linkage. Remove your center tray and when you are in there remove the trans. cover from the seat box, this allows access to the linkage, I am sure I just removed the plastic ball joint and adjusted it down the rod about 10mm. Think I used longer M6 bolts on front mounting points and made up spacers with M6 penny washers, about 10mm should do. Best way to learn, just take it apart and get torn in! ![]() |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677 ![]() ![]() |
before starting a new topic, is there any photos of these seats in the back of a 90? would really like to fit them to mine, will have the financials at the end of the month to get them...
Hi,
posted this on youtube.: |
going to purchase some next month and give it a blast not going to alter the arches and going to use puma forward facing seats..
