Home > Puma (Tdci) > Erratic Driver side Wiper
leeds
12 plate 90 with intermittent wiper mode about 10% of the time it works correctly.
Stopping at the horizontal position and vertical position about 0.5-1" from the vertical edge of the windscreen.
80% of the time it passes over the bottom windscreen seal.
10% of the time it goes over the the bottom edge and the vertical edge of the winscreen.
Any clues folks?
Brendan
Passenger side works fine/
Post #195233 20th Dec 2012 10:07pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Loose bolt ?
Post #195234 20th Dec 2012 10:13pm
bob neville
Arm moving on the spindle ?
Check the retaining nut is done up. If it is could be worn splines on the shaft or arm ?
2013 Defender 90 CSW - sold
Post #195235 20th Dec 2012 10:14pm
LR90XS2011
could be a knackered wiper wheel box gear or rack? try pushing it back and forth when parked if it moved more than about 5 degrees then call on your warranty had the same fault on a 1961 mini but was easy to access on that DEFENDER 90 TDCI XS,
Post #195236 20th Dec 2012 10:15pm
leeds
Thanks.
Will have a look in the morning when hopefully it will be dry
Brendan
Post #195237 20th Dec 2012 10:16pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
Mine was a cock hair out of alligment Brendan - which irritated me, so I adjusted it, but you will need a small 'puller' to do it, then re-tighten, maybe yours is a bit loose? Euro-Leafing to infinity and beyond.....
Post #195607 22nd Dec 2012 1:07am
leeds
Managed to compare the wipers in park position on the 3 year old 110 and the 6 month old 90.
Movement on wipers on 110 about 1/2" on the 90 about 4"
Booked in at Copleys as think it is more then a simple alignment or nut tightening as no obvious movement on spindle.
Brendan
Post #195673 22nd Dec 2012 2:08pm
familymad
Ours sis this.
Was the wiper gears. Plastic on a TDCI whereas they were metal on a TDi. Not sure about TD5 ones. Progress 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #195748 22nd Dec 2012 7:22pm
Killer90
Site Sponsor
the 110 does this, i just had the dash out to replace the passenger wheel box and know the drivers side wiper has started to stop below the windscreen Big Cry i have sorted it by taking the wiper off, then turning the wipers on once and sticking it back on cured it Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #195751 22nd Dec 2012 7:26pm
leeds
Two new wheel boxes being replaced at Copley next week Thumbs Up
Brendan
Post #196655 27th Dec 2012 12:08pm
