![]() | Home > Puma (Tdci) > Erratic Driver side Wiper |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Loose bolt ?
Arm moving on the spindle ?
Check the retaining nut is done up. If it is could be worn splines on the shaft or arm ? Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
could be a knackered wiper wheel box gear or rack? try pushing it back and forth when parked if it moved more than about 5 degrees then call on your warranty had the same fault on a 1961 mini but was easy to access on that DEFENDER 90 TDCI XS,
Thanks.
Will have a look in the morning when hopefully it will be dry Brendan |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
Mine was a cock hair out of alligment Brendan - which irritated me, so I adjusted it, but you will need a small 'puller' to do it, then re-tighten, maybe yours is a bit loose? Euro-Leafing to infinity and beyond.....
Managed to compare the wipers in park position on the 3 year old 110 and the 6 month old 90.
Movement on wipers on 110 about 1/2" on the 90 about 4" Booked in at Copleys as think it is more then a simple alignment or nut tightening as no obvious movement on spindle. Brendan |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
Ours sis this.
Was the wiper gears. Plastic on a TDCI whereas they were metal on a TDi. Not sure about TD5 ones. Progress 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
the 110 does this, i just had the dash out to replace the passenger wheel box and know the drivers side wiper has started to stop below the windscreen
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Two new wheel boxes being replaced at Copley next week
![]() Brendan |
