Home > Puma (Tdci) > rear seat removal
NCTT
rear seat removal
ok so i have purchased a 6m old 90 and loooove it.
tiny prob, got a bit of a trip approaching and to be able to take the rear seats out and leave them in the garage would be v handy, then pop them back in when i return.
1 i am a complete numty at anything to do with cars
2 would it be easyish for a complete numpty as above
3 shud i forget this ?
cheers people
Post #1898 17th Apr 2008 9:53am
walfy
TJ101 has done this on his 110 PUMA and I intend doing it for my impending European trip. Ithink it's just a case of a nut and bolt job. If all the bolts are fitted in the first place Sad 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #1899 17th Apr 2008 12:35pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Have removed seats in my 110 as well.
Easy enough if you have good set sockets etc.- just nuts and bolts .
Filled in the holes left with M8 grub screws .
N.
Post #1911 18th Apr 2008 8:27am
NCTT
cheers fella,s ill have a go then.
do they completely come out i.e the bars underneath the seat that bend down and rest on the floor when the seat is down , does it come out in 1 piece ?
Post #1933 23rd Apr 2008 9:11am
sib
They lift straight out (heavier than you think though) and removal is a nut and bolt job. I covered the holes in duck tape from inside and no probs Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #1941 23rd Apr 2008 7:44pm
TJ101
Yep easy job, about a hour, taking it easy,,
Captive torx screws bar for 2 each side on the top ( see white tape), , saying that, on mine, landrover in their wisdom, forgot to put 2 in on the right hand side
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1946 23rd Apr 2008 11:17pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
TJ101 - without wanting to hijack the thread, can you please post some more photos of the carpet fitout in the rear of your 110, including under the middle seats? Standard spec. here in Aus is only rubber matting on the floor in the rear which means the wheel-arch boxes are bare metal and get scratched to Censored . I am keen to see the factory spec. matting so I can make an equivalent, one-piece rubber set for mine.
I am curious to know why Land Rover don't do the same rear loadspace coverage in rubber that they do with carpet. 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #1952 24th Apr 2008 9:32am
TJ101
solmanic wrote:
TJ101 - without wanting to hijack the thread, can you please post some more photos of the carpet fitout in the rear of your 110, .
OK, will post some in My running report thread later Very Happy California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1955 24th Apr 2008 2:55pm
TJ101
Hi solmanic
Have put some pictures on this thread 2007 Defender 110 XS, running report
Help's keep the place tidy Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1961 24th Apr 2008 6:03pm
solmanic
Thanks. 2007 Defender 110
Post #1970 28th Apr 2008 2:35am
T1G UP
time for mine to come out.
how do the belts come out? Is it s side panel off job? If so may aswell wait and fit my windows guards
Post #119674 29th Jan 2012 10:29pm
TJ101
Mine stayed in,, don't seam to get in the way. and 20 mins job to put the seats back in, when/if needed California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #119678 29th Jan 2012 10:43pm
T1G UP
ok, sounds like a plan
Post #119679 29th Jan 2012 10:47pm
Neils
Arise from the grave!
Just taken the seats out of my 90 this afternoon.
It's pretty straightforward. Depending on your toolbox the only odd bit of kit I didn't have was the 3/8" star bit socket needed to undo the bolts inside. Otherwise you need a Philips screwdriver and a 12mm spanner
The only advice as a first timer is undo the two nuts on the bolts under the rear wheel arch before you remove the bolts inside. This isn't immediately apparent but I hope this spares you the few minutes I spent trying to pull out seats still bolted to the body of the car Rolling Eyes
Also the two screws that are on the plastic covers weren't always that keen to unscrew. But a little brute force will get them out, the screws themselves aren't attaching to anything, they just push open the plastic clips that hold the covers in place.
Post #444718 10th Aug 2015 12:00am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Post #444986 10th Aug 2015 7:16pm
