Home > Maintenance & Modifications > Anyone to swap (Rear) CSW 110 springs for Utility? (td5)
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
As per title, I'm told that CSW has softer Rear springs, and I have a DCPU - wanted to soften the ride a little bit. Would anyone like a swap?
Post #193659 15th Dec 2012 10:23am
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
I thought all 110's had the same spring on apart from one exception.
Part no RKB101111 brown/purple on most but 110 sw with 7 seats has
RKB500300 white/green/green which has a slightly longer free length, presumably to counteract the extra weight of the seats.
Not sure you will get a softer genuine land rover set.
Post #193664 15th Dec 2012 11:15am
Mountain_man
Wales
JST has swappen the Brown/purples for white /green/green and reports a much nicer ride, especially when running light. He has, though, installed a set of air springs which get pumped up whenever he needs to tow heavy loads. Sort of the best of both worlds.
Post #193703 15th Dec 2012 1:16pm
MartinK
Mountain_man wrote:
JST has swappen the Brown/purples for white /green/green and reports a much nicer ride, especially when running light. .
I did the same - and report a better ride with white/green/green - and then a set of Koni Heavy Track RAID made the whole thing better still...now more like a Disco2 than a Defender. Also SWMBO's constatnt comments bout awful ride quality have stopped... Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #193716 15th Dec 2012 1:53pm
db950
When swapping from brown/purples to white/green/green did you notice a difference in ride height when unladen or wasn't it noticeable? Also when loaded are they ok or do they sag more
Many thanks
Post #193717 15th Dec 2012 2:06pm
MartinK
Many thanks
Unladen Ride Height - i didn't notice a difference, but the dip beam did project slightly lower suggesting the rear sat slightly higher...
Laden - I don't carry a lot in the back (that's what my trailer is for), usually just bikes and kayaks (and only driver and 1 passenger) so I can't comment about ride height. However I can say thta the difference in ride quality between the 2 spring types is less noticable when laden (i.e. the brown/purple were OK when laden anyway).
I believe the white/green/green are tri-rate, so the immediate travel is soft, then once that has been used, the spring hardens.
IMHO the white/green/green are much better if you're not travelling heavily loaded frequently.
On my write-up (here http://www.defender2.net/forum/topic13312.html ) I would suggest that swapping springs isn't expensive (or time-consuming) - I got a discount off dan@Duckworth on the new springs, and then sold my original springs recovering most of the outlay Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #193722 15th Dec 2012 2:30pm
appaloosadude
My thoughts exactly! I was considering doing -30mm or -50mm on the rear as well. Koni Heavy Track: are these dampers or springs?
Post #193747 15th Dec 2012 4:51pm
Koni Heavy Track are dampers, and very good the are too Thumbs Up Darren
Post #193775 15th Dec 2012 6:10pm
appaloosadude
Stupid question incoming;
Whats the difference between the KONIs and the OEM fit?
Post #193797 15th Dec 2012 7:42pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
OEM is 'Original Equipment Manufacturer' so the original ones on the truck from Land Rover or ones made to the same spec. Koni are an after market manufacturer, and produce very high quality shocks.
Post #193799 15th Dec 2012 7:53pm
appaloosadude
Perhaps I should re-phrase that. What is better about the KONI as opposed to the original Land Rover? Also, I've done a quick google, and the Koni seem to be about £180 per shock! (That seems very expensive to me). Last shocks I bought were about £50 for the pair, and were Gas.
Post #193808 15th Dec 2012 7:59pm
appaloosadude
Double post Whistle
Post #193813 15th Dec 2012 8:06pm
Retroanaconda
There's nothing wrong with the original Land Rover shocks, they will do the job fine. But they are, as with every component on the vehicle, a compromise between cost and performance. They do have the advantage of being able to get hold of them very easily, which would be a factor to consider if you were to travel far afield.
Koni are somewhat higher performance than standard shocks, but obviously the cost is higher. If your use of the vehicle and your pocket can justify/afford them then they will do a better job than the standard fit ones do.
Post #193854 15th Dec 2012 9:37pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You're looking at the 'Raid" version of the shocks, well overkill if you're not using them for off road racing. The "normal" Koni Heavy Track are around £60-£70 each, depending on the length. http://www.yorkshireoffroadclub.net/
Post #193875 15th Dec 2012 10:18pm
appaloosadude
That's more like it. Thanks Thumbs Up
Post #193878 15th Dec 2012 10:24pm
