![]() | Home > Technical > Indicator flasher fuse/relay HELP!! |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Evening all, I have had an experience in installing some LED stuff and on the whole it has gone well....just about.
I have a flasher relay/fuse thing on the link below (can upload pic on iPhone but cannot select the BCC code) the problem is I cannot work out where in the fuse area it goes, currently my indicators are flashing mentally when I indicate and the new front LED indicators dont flash at all! ![]() (Never thought I'd be asking where to put a fuse) https://www.defender2.net/gallery/displayi...pos=-9613# Many thanks ***link amended*** =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH Last edited by Lishlandy on 14th Dec 2012 10:30pm. Edited 1 time in total |
Amended, thanks Steve, had put a link to the latest picture, which at that point was my pic. I clicked it and got a strung up reindeer haha
Appreciate any help you can give, sorry its not Kenwood ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
Is the led polarity correct?
Are you using the hella ED for the SVX front grill? If yes, you need to swap the wires .... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6727 ![]() ![]() ![]() |
Try this post: http://www.defender2.net/forum/post163312.html#163312
Uh oh! Thanks, so I need to switch the wires in the connector. I thought I was out of my depth with just the plug and play stuff, now I'm changing wires across. Haha. Must remember to embrace new experiences. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 ![]() ![]() |
You have got the polarity correct on the front indicators?
The relay you're after replacing is the one that's clicking in time with your disco-fender-lights ![]() R141 is the one you're after, which according to my info is relay number 9 under your fusebox. Real trucks don't have spark plugs |
Steve swap the pos and neg around on the indicators ie cut and splice
Thanks Martin, my issue is I don't know where the relay actually goes in the area where the fuses are ![]() Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
It does say:
I don't have a Puma so can't help any further, sorry. ![]() ![]() |
Argh, apologies I must of overlooked that bit, thanks for all the help from all. I'm sure ill crack it tomorrow morning with a fresh head.
Merry Christmas. =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
NNNNNNNNNNNNOOOOOOOOOOOOOOOO
Do not swap the wires - use the loom provided they are already the right way round! Fuse box is drivers side under dash - panel rel;eased by two large slotted "screws" which you turn 90 degrees using something like a penny! Top row closest to gear lever is the flasher relay. |
