Home > Technical > Indicator flasher fuse/relay HELP!!
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Evening all, I have had an experience in installing some LED stuff and on the whole it has gone well....just about.
I have a flasher relay/fuse thing on the link below (can upload pic on iPhone but cannot select the BCC code) the problem is I cannot work out where in the fuse area it goes, currently my indicators are flashing mentally when I indicate and the new front LED indicators dont flash at all! Big Cry please can someone point me in the right direction?
(Never thought I'd be asking where to put a fuse)
https://www.defender2.net/gallery/displayi...pos=-9613#
Many thanks
***link amended*** ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #193579 14th Dec 2012 9:53pm
Link is not correct mate. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #193597 14th Dec 2012 10:21pm
Lishlandy
Amended, thanks Steve, had put a link to the latest picture, which at that point was my pic. I clicked it and got a strung up reindeer haha
Appreciate any help you can give, sorry its not Kenwood Embarassed ===================================
Steve
110 USW X-TECH
Post #193602 14th Dec 2012 10:32pm
dgardel
Italy
Is the led polarity correct?
Are you using the hella ED for the SVX front grill?
If yes, you need to swap the wires .... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #193607 14th Dec 2012 10:42pm
Martin
Site Admin
Try this post: http://www.defender2.net/forum/post163312.html#163312  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #193608 14th Dec 2012 10:42pm
Lishlandy
Uh oh! Thanks, so I need to switch the wires in the connector.
I thought I was out of my depth with just the plug and play stuff, now I'm changing wires across. Haha. Must remember to embrace new experiences. ===================================
Steve
110 USW X-TECH
Post #193616 14th Dec 2012 10:58pm
udderlyoffroad
You have got the polarity correct on the front indicators?
The relay you're after replacing is the one that's clicking in time with your disco-fender-lights Rolling with laughter
R141 is the one you're after, which according to my info is relay number 9 under your fusebox. Real trucks don't have spark plugs
Post #193618 14th Dec 2012 10:59pm
Steve swap the pos and neg around on the indicators ie cut and splice
Post #193619 14th Dec 2012 11:01pm
Lishlandy
Thanks Martin, my issue is I don't know where the relay actually goes in the area where the fuses are Embarassed I can change a blade far but these relay hobbies are baffling where they go, the explanation on the cover offers no clarity of which does which ===================================
Steve
110 USW X-TECH
Post #193621 14th Dec 2012 11:03pm
Martin
Site Admin
It does say:
Quote:
Top left hand corner of fuse box located under steering wheel
I don't have a Puma so can't help any further, sorry.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #193624 14th Dec 2012 11:55pm
Lishlandy
Argh, apologies I must of overlooked that bit, thanks for all the help from all. I'm sure ill crack it tomorrow morning with a fresh head.
Merry Christmas. ===================================
Steve
110 USW X-TECH
Post #193627 15th Dec 2012 12:15am
mobilecentre
NNNNNNNNNNNNOOOOOOOOOOOOOOOO
Do not swap the wires - use the loom provided they are already the right way round!
Fuse box is drivers side under dash - panel rel;eased by two large slotted "screws" which you turn 90 degrees using something like a penny!
Top row closest to gear lever is the flasher relay.
Post #193730 15th Dec 2012 3:22pm
