Home > Maintenance & Modifications > Will it fit in a Puma tray - Odyssey PC1500?
ZeDefender
As title - can I straight swap an Odyssey PC1500 with the OEM Puma 2.4 battery without any modifications?
Did a search but couldn't quite get the specific answer.
Would be great if someone has done it Smile
I would go and measure but it's -5 and dark outside and I've only just got warm Whistle
Thanks
Matt Tell someone you love them today because life is short.
Post #193511 14th Dec 2012 5:33pm
leeds
Have only taken out existing one and replaced with twin 1500.
1500 size is W 275.6 x D 171.7 x H 198.6 mm
I think it will probably be a straight swap but can not guarantee it. I seem to think that the red plastic cover over the positive terminal lead needs trimming.
Brendan
Post #193527 14th Dec 2012 6:07pm
bob neville
Yes Thumbs Up
I have the 1500DT (double terminal version) and it fits the Puma and TD5.
As Brendan said, you may need to trim the red + cover a bit.
2013 Defender 90 CSW - sold
Post #193530 14th Dec 2012 6:17pm
ZeDefender
Brilliant - thanks guys Bow down
Post #193541 14th Dec 2012 6:49pm
leeds
A couple of general tips.
If the positive terminals are not covered by a plastic cover, consider fitting one, use a piece of rubber over uncovered positive terminals or use insulating tape on underside of battery box lid.
If using crocodile clips to jump start a vehicle use fully insulated clips, otherwise you might see some rather big sparks.
Brendan
Post #193543 14th Dec 2012 6:58pm
ZeDefender
Good advice and something I often forget Embarassed
I know all about sparks - before we got the speed controller for the go-kart:
we tested the motor a bit by earthing the battery on the plate:
It was then I realised you could weld aluminium :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #193555 14th Dec 2012 7:28pm
