![]() | Home > Maintenance & Modifications > Will it fit in a Puma tray - Odyssey PC1500? |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
As title - can I straight swap an Odyssey PC1500 with the OEM Puma 2.4 battery without any modifications?
Did a search but couldn't quite get the specific answer. Would be great if someone has done it I would go and measure but it's -5 and dark outside and I've only just got warm Thanks Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
Yes
I have the 1500DT (double terminal version) and it fits the Puma and TD5. As Brendan said, you may need to trim the red + cover a bit. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Brilliant - thanks guys
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
A couple of general tips.
If the positive terminals are not covered by a plastic cover, consider fitting one, use a piece of rubber over uncovered positive terminals or use insulating tape on underside of battery box lid. If using crocodile clips to jump start a vehicle use fully insulated clips, otherwise you might see some rather big sparks. Brendan |
Good advice and something I often forget
I know all about sparks - before we got the speed controller for the go-kart: Click image to enlarge Click image to enlarge we tested the motor a bit by earthing the battery on the plate: Click image to enlarge It was then I realised you could weld aluminium :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated But shout it at them in German because life is also terrifying and confusing... |
| All times are GMT |
