Home > Maintenance & Modifications > wing top checker plate
Ric
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Thinking of fitting some black wing top checker plate.
However i'm not sure about drilling holes in the wings, problem arises when i get fed up with them and want them off!
Could they be stuck on, so when off any marks can be polished out rather than having holes filled and sprayed its only a car!
Post #193357 14th Dec 2012 1:55am
There's no reason why not if you can find a suitably weatherproof but non-permanent adhesive. It'll have to be pretty strong though, as I'd imagine the uplift force from the wind on the leading edge would be significant above, say, 50mph.
The only other problem may be that all the decent chequer plate kits are pre-drilled with countersunk holes, so you'd need to do some faffing about with false bolt heads to disguise them. Darren
Post #193368 14th Dec 2012 7:56am
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Not sure I'd have any faith the glue was strong enough to stop them flying off on a motorway but weak enough to be removable one day.
Post #193375 14th Dec 2012 8:19am
macduff
Silkaflex might do it .
Post #193380 14th Dec 2012 8:36am
Thud
You'd never get it off again.
Post #193381 14th Dec 2012 8:38am
macduff
Lol possibly might lift paint on removal I'm only aware of its use in sticking bits to TVRs
Post #193382 14th Dec 2012 8:48am
Thud
They do pretend to make a solvent but I wouldn't want to test it on my car.
Post #193383 14th Dec 2012 8:49am
Ric
Crying or Very sad Drilling it is then Crying or Very sad its only a car!
Post #193392 14th Dec 2012 9:54am
If you really really hate it, you could always fit another pair of wings !
Post #193393 14th Dec 2012 9:55am
Happyoldgit
I wouldn't rate your chances of getting them off without damage if you use Sikaflex Laughing If you prepare the panels well I would have thought using a good quality double sided vehicle body tape would suffice but you would need plenty of it - and patience if it ever changed your mind and wanted to remove the plate, you still might run the risk of damaging the vehicle finish even with a good and safe solvent.
Do you want them for their functionality or for the way they make the vehicle look and for what that implies? The original point of riveting thick bits of aluminium to the wing and bonnet tops was to provide additional strength to permit walking on them to gain access to the roof, it also served to protect the wing panels underneath from dents and damage from tools and elbows while working in the engine bay. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #193394 14th Dec 2012 9:57am
K9F
I find the wing top chequerplate the most useful of all. Cups of tea, coffee, tools etc. and of course leaning on. Without it the wings would undoubtedly get dented/marked quite quickly.
Here's a picture of my mates when his overweight Mrs lent on his wing to see what he was doing under the bonnet...bet he wished he'd fitted chequerplate. Laughing
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #193395 14th Dec 2012 10:02am
Naks
Re: wing top checker plate
Ric wrote:
Thinking of fitting some black wing top checker plate. However i'm not sure about drilling holes in the wings, problem arises when i get fed up with them and want them off!
You won't get fed up with them, just drill the holes. Thumbs Up --
Post #193405 14th Dec 2012 10:50am
Had a quick search but can't seem to find it now - can anyone remember or point me in the right direction for the thread relating to inner strengthening brackets that could be or even where required to stop the wings bending in if you did walk on them?
Post #233330 7th May 2013 9:00am
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Post #233334 7th May 2013 9:22am
appaloosadude Thumbs Up
Excellent - top wing support brackets...no obvious threads about them:
So a few questions:
1. Anyone fitted them?
2. Do they do the job?
3. Any photos of them fitted?
4. Does anyone else do an alternative support?
Post #233335 7th May 2013 9:27am
