![]() | Home > Maintenance & Modifications > wing top checker plate |
Well I can see you have used them:
![]() Click image to enlarge and photos/feedback? |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Not fitted to my 90 but wish I had as the wingtops on this both bent due to getting on them to put tent away. ![]() I have them fitted to my 130 a good idea but like all Entreq products way over priced. |
Well if this is a common failing, and given the amount of chequerplate I've seen, it's surprising that more people are not shouting for aftermarket solutions, especially given the price point of the Entreq ones. |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2276 ![]() ![]() |
. Never mind wing top protection ! If ever there was a reason to fit a front external roll cage then this is it . What about head protection ? |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I bought some black 3mm wingtops a couple of months ago.. The fit was abysmal, with massive gaps at the leading edge and they went straight back to the supplier... I waited nearly a month for them to be delivered, and then when they were returned, there wasn't an apology or hint that they would be replaced with the correctly fitting items... Their other bits I have bought from the same people are great... ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
