![]() | Home > Off Topic > Towing a trailer with led lights |
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
When I built my trailer I used LED lights and had the same issue I ended up fitting ballast resistors to the indicators to make them function correctly and my towing tell tale work correctly. I chose to do it this way rather than changing the flasher unit as I tow other trailers and it would have messed the flashing rate on these up.
Jason. Last edited by jasong4110 on 13th Dec 2012 11:57pm. Edited 1 time in total |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
You need to change the flasher relay in the Disco for one which supports LED lights. There's loads on ebay or alternatively PM Tim at The Mobilecentre who's a site sponsor on here as he carries them.
Pete |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
It is definatly a cure but they do flash a bit slow for my liking If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
No flasher relay in a D3 as such (body controller), you will need ballasts or hidden bulbs I'm afraid
He has others that cure the slow flash as well the early relays did this not the newer ones ![]() |
