Home > Puma (Tdci) > Replacing Headlight bulbs
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
When replacing headlight bulbs I assume you do it from the outside. Does one take off that big plastic squate plate or can you only somehow screw out the lens housing itself?
Post #192952 12th Dec 2012 4:41pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Yes from the outside, you'll find out how rusty the retainer rings are when you do it Laughing
Post #192953 12th Dec 2012 4:53pm
Take out the sidelight and indicator the the plastic panel and go from there.. Easier access then otherwise you risk dripping the light by accident. You also only need to remove one screw on the headlight bezels or you will put the adjustment out of alignment. Hopefully someone will be along shortly to tell you the exact positioning of the screws I mean. I'm afraid I can't remember now. Thumbs Up HennesseyVenomF5
LoneStar⭐️State
WeWillWin🇬🇧🇺🇸
Post #192954 12th Dec 2012 4:55pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
On my TD5 I did it through the back, because I'm an awkward sod.
Post #192960 12th Dec 2012 5:29pm
Marius
No space in the Puma to do them from the back Sad
Post #192962 12th Dec 2012 5:37pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Post #193010 12th Dec 2012 8:50pm
kmac
of the four screws in the main headlight bezel the ones in the 12 o'clock and 9 o'clock position are used to adjust the beam alignment
Post #193012 12th Dec 2012 8:56pm
Sounds right to me. I did it myself but was nearly a year ago so I've forgot which one's now off the top of my head. Thumbs Up HennesseyVenomF5
LoneStar⭐️State
WeWillWin🇬🇧🇺🇸
Post #193013 12th Dec 2012 8:58pm
kmac
custom90steve wrote:
You also only need to remove one screw on the headlight bezels or you will put the adjustment out of alignment.:
Are you saying you can remove the glass and access the bulb by only removing one of the four screws holding the glass to the bezel?
Post #193015 12th Dec 2012 8:59pm
kmac
Post #193017 12th Dec 2012 9:02pm
Yes I did. Mainly because I didn't want to mess the alignment up. Turns out MOT time I did anyway by changing over to Crystals anyway I assume because of a different unit. However for a simple bulb change you should only have to remove one screw per headlight remove change and re-fit. As simple as that. HennesseyVenomF5
LoneStar⭐️State
WeWillWin🇬🇧🇺🇸
Post #193024 12th Dec 2012 9:16pm
MartinK
Nice little write-up here you may find useful in buster's guides...
http://www.landyzone.co.uk/lz/f41/headlight-renewal-130728.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #193036 12th Dec 2012 9:58pm
Happyoldgit
It really is a simple 5-10 minute job. Do it as per kmac's pic from the handbook above. Once you have the indicator and sidelight units off and removed the plastic trim, remove the four larger cross head screws that secure the bowl to the wing and pull the whole lot complete with headlamp leveller out. There's no need to touch the bezel screws, the headlamp adjuster screws are the ones with the springs underneath so there should be no confusing them.
One thing to watch for is don't let any of he four screws drop down through the small slit in the headlamp box - best cover that with a bit of masking tape first. One trick is to use double sided tape which will ensure the screw will just drop and stick and not fall down through the slit into a small box section from which they are a PITA to get out. Steve.
http://forums.lr4x4.com
Post #193039 12th Dec 2012 10:05pm
Marius
I'll give it a go tonight.
I'm fitting H4 55W Xenons.
Thanks for all the diagrams guys.
Post #193118 13th Dec 2012 12:36pm
Retroanaconda
Spoken like a man with true experience of Land Rovers. I lost half-an-hour to a screw in that slot before!
Post #193268 13th Dec 2012 9:22pm
