Home > Puma (Tdci) > Replacing Headlight bulbs
Page 2 of 2 <12
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I did the left light last night. Not a major difference with those Xenon h4's. The lights are now allot more (white) as aposed to yellow and the intensity is more by about 15%.
Post #193358 14th Dec 2012 5:55am
rossy
kmac wrote:
of the four screws in the main headlight bezel the ones in the 12 o'clock and 9 o'clock position are used to adjust the beam alignment
Are you sure ?
I've had my headlights off three times now and from memory its the screws at 3 oclock, 9 oclock and the motorised one (connected to the height adjustment knob on the dash) at 6 oclock where adjustments need to be made. I just kind of figured it out so if I've done it wrong please advise !
Post #193522 14th Dec 2012 7:01pm
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
Retroanaconda wrote:
Miserableolgit wrote:
One thing to watch for is don't let any of he four screws drop down through the small slit in the headlamp box - best cover that with a bit of masking tape first. One trick is to use double sided tape which will ensure the screw will just drop and stick and not fall down through the slit into a small box section from which they are a PITA to get out.
Spoken like a man with true experience of Land Rovers. I lost half-an-hour to a screw in that slot before!
I've just dropped a screw thru the slot - if you take the headlamp back out you can easily get access to retrieve the screw Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #234623 11th May 2013 1:50pm
keith
PIAA chrome extreme white . 4100 K no blue tinge and a perfect sharp bright white . Not cheep at 90
Post #234687 11th May 2013 5:55pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Old thread, but Ive just shafted my alignment and my headlamp vertical adjuster doesnt work now either after I made a right fanny of bulb changing.
Shouldve read this first. Rolling Eyes
Post #667335 27th Nov 2017 7:12pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Replacement bits are cheap enough. Headlight fitting kit STC1614 contains most of what you need for 8. My local tyre/MOT garage adjusted the headlights for free.
Post #667399 27th Nov 2017 10:22pm
Doc P
Thanks Balvaig. My local garage fixed the issue FOC too (I hadn't located the screws at 6 o'clock in the slot properly - both sides!!) but my offside adjuster motor now just makes a buzzing noise. Will have to try and find it. The other works OK.
Ian
Post #667556 28th Nov 2017 4:10pm
Balvaig
From memory it is behind the bowl which is behind the light. Might just need lubricating. Worth switching the setting from 0-3 and back a few times and watch whether the headlight adjusts. Might also be mislocated. Pretty certain you will have to remove the headlight again to get at it. Big Cry
Post #667576 28th Nov 2017 6:29pm
Sockpuppet
Make sure the adjuster is in the slot of the headlight ring and not behind it.
Post #667593 28th Nov 2017 7:22pm
Doc P
Thanks lads👍 I’ll wait till it’s a bit warmer and have another look.
Post #667720 29th Nov 2017 7:25pm
Page 2 of 2 <12
