Home > Maintenance & Modifications > Puma interior light
simonpuma90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Puma interior light
Hi guys looking for some info on my interior lights they have recently packed in on the door switches but work fine if you switch them on I have had all the pins out of the doors and cleaned them up and done a continuity test on them all ok and they refuse to come on still any idea where the wires go before I start tracing
Thanks
Post #192550 10th Dec 2012 9:44pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Check and see if the alarm goes off when you open the doors. It's the alarm module which controls the lights coming on with the doors.
Post #192558 10th Dec 2012 10:06pm
simonpuma90
Funny you should say that I noticed my indocators stopped flashing the other day when I lock and unlock it so I checked the fuses and there was one blown under the seat no they work bu no interior lights still where is the module in the same place ?
Post #192560 10th Dec 2012 10:11pm
me@td5.org
I don't know where it is on a Puma but can't hurt to check the old place.
Post #192581 10th Dec 2012 10:43pm
simonpuma90
Will do thanks
Post #192849 11th Dec 2012 10:24pm
simonpuma90
I'm really struggling with this anyone had the same problem
Post #198272 1st Jan 2013 10:06pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Is your alarm unit working ok? Do indicators flash when locking / unlocking car?
http://www.defender2.net/forum/post196844.html#196844
Post #198281 1st Jan 2013 10:31pm
simonpuma90
Indicators work when locking , alarm goes off as the hail stones tested it for me the other night , all pins been tested and cleaned still no lights
Post #198283 1st Jan 2013 10:35pm
Lorryman100
A couple of things spring to mind, is the switch actually making contact with the strip in the housing when placed to on? Also the 10AS can be a bit temperamental so if the fobs batteries are OK do a Hard reset, disconnect the earth from the battery then press the brake pedal a few times to dissipate any stored capacitance. After 10 mins reconnect and see if anything has changed. The radio code should still be pre-set in the radio but if it is an aftermarket radio you may need the radio code. Thumbs Up
Brian.
Post #198285 1st Jan 2013 10:37pm
dgardel
Italy
fob battery low?
from the User Manual:
When the battery needs replacing, it will be
apparent from the following symptoms:
• The remote control will only work every
other operation when unlocking.
• The hazard warning lamps will not flash
when the alarm is disarmed.
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #198311 2nd Jan 2013 6:43am
Merlin
Hope it’s the fob battery, as the AS10 is a b*gger to get to. It’s behind the speedo console, tucked away. I think it’s the first thing they fit and then put the rest of the car around it.
Merlin
Post #198406 2nd Jan 2013 4:23pm
simonpuma90
did the battery last night and no joy must be the AS10 Big Cry
Post #198570 3rd Jan 2013 10:21am
