![]() | Home > Maintenance & Modifications > Puma interior light |
| me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856
Check and see if the alarm goes off when you open the doors. It's the alarm module which controls the lights coming on with the doors.
| simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472
Funny you should say that I noticed my indocators stopped flashing the other day when I lock and unlock it so I checked the fuses and there was one blown under the seat no they work bu no interior lights still where is the module in the same place ?
I don't know where it is on a Puma but can't hurt to check the old place.
Will do thanks
I'm really struggling with this anyone had the same problem
| Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377
Is your alarm unit working ok? Do indicators flash when locking / unlocking car?
http://www.defender2.net/forum/post196844.html#196844 |
Indicators work when locking , alarm goes off as the hail stones tested it for me the other night , all pins been tested and cleaned still no lights
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
A couple of things spring to mind, is the switch actually making contact with the strip in the housing when placed to on? Also the 10AS can be a bit temperamental so if the fobs batteries are OK do a Hard reset, disconnect the earth from the battery then press the brake pedal a few times to dissipate any stored capacitance. After 10 mins reconnect and see if anything has changed. The radio code should still be pre-set in the radio but if it is an aftermarket radio you may need the radio code.
Brian. |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
fob battery low? from the User Manual: When the battery needs replacing, it will be apparent from the following symptoms: • The remote control will only work every other operation when unlocking. • The hazard warning lamps will not flash when the alarm is disarmed. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Hope it’s the fob battery, as the AS10 is a b*gger to get to. It’s behind the speedo console, tucked away. I think it’s the first thing they fit and then put the rest of the car around it.
Merlin |
did the battery last night and no joy must be the AS10
| All times are GMT |
