![]() | Home > Technical > Jumping query |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
I had visions of a 110 flying through the air over the top of a mini or something then....
Silly me! As far as i know there are no special procedures, i have jumped a few cars using my 2009 90 with no problems. Just have a look in the manual. Regards, Mark |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Ha ha - that had crossed my mind as I made the post. ![]() Thanks for the info though, sets my mind at ease. |
Standard jumping procedure really but watch out for any uninsulated bits of the positive jump connection touching the lip or sides of the battery box. Steve.
Good point - thanks! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8341 ![]() ![]() ![]() |
take the good (ie Puma) -ve to an earth on the block/chassis rather than the stricken -ve post. Cheers
Be VERY careful what you are jumping - a lot of modern cars DO NOT allow you to jump them - You have to disconnect their battery or risk frying the very expensive ECU - If in doubt don't do it !
http://www.theaa.com/motoring_advice/break...leads.html |
What you described is exactly what happened with my wife's car. ![]() This time however I'm only jumping another Landie, an old 1983 One Ten. No ECU to deal with, just lots of dust and some rust. ![]() |
I did the same with Mrs FCX's X5
