Home > Maintenance & Modifications > Check your Noisekiller engine blanket for chafing !
rossy
I noticed today that my NK blanket was rubbing against what looks like an air hose running across the top of the engine and had worn the surface away a little. Ditto a fuel pipe (I think) at the front RHS of the engine. The blanket has been on for just over a year and where it gets creased the lead middle layer gets a bit pointy. I wedged some soft heat proof pipe insulation between it and the two surfaces mentioned above so that should stop the wear.
If you have one of these it might be worth checking.
Post #191200 5th Dec 2012 4:34pm
Knot Yet
England 2012 Defender 110 Puma 2.2 USW Orkney Grey
Mine was mullered in less than a year due to wearing through, disappointing in all honesty and I won't both again will use ear plugs Rolling Eyes Very Happy Defender 110 Puma Utility XS
Post #191265 5th Dec 2012 10:11pm
ZeDefender
Mine chafed underneath and on top where it was touching the bonnet. Tell someone you love them today because life is short.
Post #191266 5th Dec 2012 10:19pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
2 years on and mine is still OK, no noticeable wear BM52
Post #191269 5th Dec 2012 10:34pm
ZeDefender
bm - is yours a TD5? Tell someone you love them today because life is short.
Post #191273 5th Dec 2012 10:45pm
bm52
TDCI Puma BM52
Post #191275 5th Dec 2012 10:50pm
ZeDefender
Confused cheers Tell someone you love them today because life is short.
Post #191276 5th Dec 2012 11:02pm
Knot Yet
Maybe it's the distance travelled rather than how many years that defines how worn they get?
My mullered one covered 16,000 miles before becoming pointless Defender 110 Puma Utility XS
Post #191292 6th Dec 2012 6:39am
ZeDefender
About the same as mine - I have to admit I gave up with mine as it was obviously fouling the bonnet and seemed to be making more noise (I used a dB meter at various RPMs). There may also have been some heat issues with a dodgy CHT sensor but that's far from certain.
Not slating the blanket as many members swear by it. I just reckon the stick-on stuff would be better for me. Tell someone you love them today because life is short.
Post #191293 6th Dec 2012 6:57am
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
is there no way to stick the blanket to the bonnet lid? maybe that would work and avoid the rubbing?
Post #191392 6th Dec 2012 8:04pm
ZeDefender
I think the weight would be the problem - it's basically a lead sheet and bloody heavy which is why it should work. I doubt any glue would hold it and the bonnet would be even heavier... mine already has plate on it Shocked Tell someone you love them today because life is short.
Post #191395 6th Dec 2012 8:11pm
adiep
Idea
No-More-Nails? Laughing
Post #191443 6th Dec 2012 10:00pm
T7mbo
Took mine off after 10 days of use.
I reckon the inside was louder with the blanket!
Got it in the garage if anybody is interested!
Post #191465 6th Dec 2012 11:47pm
adiep
Really? just goes to show.. I was convinced these things worked wonders, looks like they are a bit useless.
Post #191491 7th Dec 2012 8:30am
ZeDefender
Some people swear by them but I expect a lot depends upon the engine. Pumas are much quieter than older models anyway so the gains might not be as great as with e.g. a TD5. I didn't notice any improvement, so when it started looking tatty, I just took it off to lose weight. Wish I could do that to myself Laughing
"Nothing ventured" and all that... Tell someone you love them today because life is short.
Post #191495 7th Dec 2012 8:39am
