![]() | Home > Maintenance & Modifications > Intermittent Wiper Mod |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
I had modified the front wipers some time ago by replacing the relay with the VW 99 relay to good effect.
Then I followed Dgardel's instructions to fit the old front relay to make the rear wiper intermittent. Which works well. I'm not an electronics expert, but If I replaced the modified rear relay with another VW 99 relay would I now have variable intermittent rear wiper or is extra wiring required?
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
You can .... there was a post on here about it at the time [can't remember how though]
Do a search |
Found it
http://www.defender2.net/forum/topic1810.h...p;start=30 End of page, post by Barney Rubble Guns and Landrovers .... anything else is irrelevant. |
You wont regret it .. best ever mod you can do
Thanks Dave-H. I've seen that post. A bit too "electronic" for me. I was referring to this post/mod by Dgardel
http://www.defender2.net/forum/topic11573....iper+relay If you get fixed intermittent wiping by substituting the original Front wiper relay for the Rear relay + the wiring modification. What happens if you use another VW 99 relay?? Do you then get variable timed intermittent rear wiping??
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Yes
So if someone can correct me if I am wrong.
Just doing Dgardels mod in the above link but using a VW 99 relay you get variable intermittent wipe. Using Barney Rubbles rewiring mode using the VW 99 gives you variable wipe + screen wash as well?????
| All times are GMT |
