Home > Maintenance & Modifications > Intermittent Wiper Mod
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I had modified the front wipers some time ago by replacing the relay with the VW 99 relay to good effect.
Then I followed Dgardel's instructions to fit the old front relay to make the rear wiper intermittent. Which works well.
I'm not an electronics expert, but If I replaced the modified rear relay with another VW 99 relay would I now have variable intermittent rear wiper or is extra wiring required? Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #190866 4th Dec 2012 4:48pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
You can .... there was a post on here about it at the time [can't remember how though] Embarassed
Do a search Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #190867 4th Dec 2012 4:50pm
Dave-H
Found it Thumbs Up
http://www.defender2.net/forum/topic1810.h...p;start=30
End of page, post by Barney Rubble Guns and Landrovers .... anything else is irrelevant.
Post #190871 4th Dec 2012 4:56pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Oooh , thanks for trawing that thread up chaps.
Just orderred a relay of fleabay for the front to see how well it works, then will probably fit the original on the rear with a view to using anothr VW one if the first is succesful He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #190876 4th Dec 2012 5:18pm
Dave-H
You wont regret it .. best ever mod you can do Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #190877 4th Dec 2012 5:21pm
WelshGas
Thanks Dave-H. I've seen that post. A bit too "electronic" for me. I was referring to this post/mod by Dgardel
http://www.defender2.net/forum/topic11573....iper+relay
If you get fixed intermittent wiping by substituting the original Front wiper relay for the Rear relay + the wiring modification. What happens if you use another VW 99 relay??
Do you then get variable timed intermittent rear wiping?? Thumbs Up LANDYWATCH
Post #190904 4th Dec 2012 6:22pm
mk1collector
Yes Thumbs Up
Post #190932 4th Dec 2012 7:48pm
WelshGas
So if someone can correct me if I am wrong.
Just doing Dgardels mod in the above link but using a VW 99 relay you get variable intermittent wipe. Using Barney Rubbles rewiring mode using the VW 99 gives you variable wipe + screen wash as well????? Bow down LANDYWATCH
Post #191005 4th Dec 2012 10:31pm
