![]() | Home > Puma (Tdci) > Help! Doors unlock then re-lock straight away |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
check this thread:
http://www.defender2.net/forum/topic5177.h...k+freezing |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 ![]() ![]() |
Going slightly OT
Puma 90, front doors unlock on key fob but have to unlock rear door on key. Puma 110, all doors unlock on key fob. So should 90 rear door unlock on key fob as well? This is not temperature related. Brendan |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6519 ![]() ![]() ![]() |
Check they've fitted the solenoid to the rear door!
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11240 ![]() ![]() ![]() |
The solenoid on the drivers door is not achieving its' full travel and so, for want of a better description, is bouncing back to the locked position. It affects all doors because the drivers door one is the master for the system. The reason it's not achieving full travel in the cold weather is almost certainly because the grease applied to the mechanism has become very thick and is generating too much resistance to the movement. Strip, clean and re-lubricate with something like white grease. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
May not be as daft as it sounds. It is a Land Rover after all! However I am convinced it locks ok on the fob. It is not here so I will have to check later. A one way solenoid??? Brendan |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6769 ![]() ![]() ![]() |
The drivers door solenoid will have frozen and as the drivers door lock unlocks the rest (as in when you lock it with the key) it will be telling the rest of the locks to close. Plenty of wd40 after it all thaws out!
Edit: got beaten too it because someone came to the door ![]() |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Brendan,My 90 does the same as yours all 3 doors lock on the fob but only the front 2 unlock on the fob.I beleive this is down to a defective rear door solenoid as have had similar issues with discoveries at work,the solenoid is,nt very expensive but i have decided to leave mine as it is as i quite like the idea that the back door stays locked unless i have purposely unlocked it. 2005 Td5 90 XS
Steve |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6677 ![]() ![]() |
It may well be just adjustment that is required on the rear door solenoid.
It's probably moving / responding to the fob but isn't 'throwing' the lock quite far enough When you fit the rear door holding open thingy you can check ![]() |
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1366 ![]() ![]() ![]() |
Thanks for tall the replys - looks like a pretty easy fix. I was imagining all sorts of fancy ecu's needing to be replace, and just as soon as the warranty had run out too! Euro-Leafing to infinity and beyond.....
In our case the 90 is going into the main dealers on Monday as have water ingress into drivers footwell.
So they can sort it out! ![]() Hope you do not mind me sharing the thread Strang but it seemed simpler to do that then start a new thread! Brendan |
No worries Brendan! - are you going to Copley?
Guess what - got home tonight (Mrs Strang's Mini came to the rescue) and the doors unlocked on the first blip as normal ![]() |
Yes it will be going to Copleys. They appear to be friendlier then Farnells. However their offers of collection or dropping driver off seems to be shall we say a bit poor/erratic. However they do appear to be helpful enough.
Brendan |
That's because the solenoid will have thawed like I said earlier. Get some wd40 sprayed on it now and it shouldn't happen again ![]() |
I know it's a long shot but on the mrs polo you blip the fob once to open the drivers door and a second time to unlock both doors. Maybe if you blip the fob twice the rear door will unlock. I know it's a Landrover and unlikely but I thought worth a try maybe? Ray |
