Home > Puma (Tdci) > Help! Doors unlock then re-lock straight away
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
OK – not used my Puma since Monday (when, surprisingly the warranty expired! ) . So this morning I press the ‘unlock’ option on my key fob and the doors unlock, then instantly re-lock themselves. This happened every time I tried the fob, the car would unlock, then instantly re-lock itself? I have had to come to work, so not had much time to fiddle around with it. The only difference from a ‘normal’ day is that there was a hard frost last night, but only down to -3 ish, nothing extreme. I have only tried my fob and not the spare at the moment too.
I called in at the main stealer on the way in to work to ask them, and they suggested water had got into a lock, and frozen, but surely this would not affect all three locks – ie both front doors (it’s a 90) and the rear door?
Any ideas anyone please? Euro-Leafing to infinity and beyond.....
Post #189430 29th Nov 2012 9:35am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Post #189435 29th Nov 2012 10:03am
leeds
Going slightly OT
Puma 90, front doors unlock on key fob but have to unlock rear door on key.
Puma 110, all doors unlock on key fob.
So should 90 rear door unlock on key fob as well?
This is not temperature related.
Brendan
Post #189439 29th Nov 2012 10:14am
Martin
Site Admin
Check they've fitted the solenoid to the rear door!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #189444 29th Nov 2012 10:33am
Re: Help! Doors unlock then re-lock straight away
The solenoid on the drivers door is not achieving its' full travel and so, for want of a better description, is bouncing back to the locked position. It affects all doors because the drivers door one is the master for the system.
The reason it's not achieving full travel in the cold weather is almost certainly because the grease applied to the mechanism has become very thick and is generating too much resistance to the movement. Strip, clean and re-lubricate with something like white grease. Darren
Post #189455 29th Nov 2012 11:51am
leeds
May not be as daft as it sounds. It is a Land Rover after all!
However I am convinced it locks ok on the fob. It is not here so I will have to check later.
A one way solenoid???
Brendan
Post #189457 29th Nov 2012 12:01pm
mk1collector
The drivers door solenoid will have frozen and as the drivers door lock unlocks the rest (as in when you lock it with the key) it will be telling the rest of the locks to close. Plenty of wd40 after it all thaws out!
Edit: got beaten too it because someone came to the door Mr. Green
Post #189460 29th Nov 2012 12:09pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Brendan,My 90 does the same as yours all 3 doors lock on the fob but only the front 2 unlock on the fob.I beleive this is down to a defective rear door solenoid as have had similar issues with discoveries at work,the solenoid is,nt very expensive but i have decided to leave mine as it is as i quite like the idea that the back door stays locked unless i have purposely unlocked it. 2005 Td5 90 XS
Steve
Post #189464 29th Nov 2012 12:13pm
It may well be just adjustment that is required on the rear door solenoid.
It's probably moving / responding to the fob but isn't 'throwing' the lock quite far enough
When you fit the rear door holding open thingy you can check Mr. Green
Post #189477 29th Nov 2012 12:55pm
strang
Thanks for tall the replys - looks like a pretty easy fix. I was imagining all sorts of fancy ecu's needing to be replace, and just as soon as the warranty had run out too! Euro-Leafing to infinity and beyond.....
Post #189483 29th Nov 2012 1:45pm
leeds
In our case the 90 is going into the main dealers on Monday as have water ingress into drivers footwell.
So they can sort it out! Razz
Hope you do not mind me sharing the thread Strang but it seemed simpler to do that then start a new thread!
Brendan
Post #189487 29th Nov 2012 2:02pm
strang
No worries Brendan! - are you going to Copley?
Guess what - got home tonight (Mrs Strang's Mini came to the rescue) and the doors unlocked on the first blip as normal Mad Euro-Leafing to infinity and beyond.....
Post #189594 29th Nov 2012 8:47pm
leeds
Yes it will be going to Copleys. They appear to be friendlier then Farnells. However their offers of collection or dropping driver off seems to be shall we say a bit poor/erratic. However they do appear to be helpful enough.
Brendan
Post #189656 29th Nov 2012 10:09pm
mk1collector
That's because the solenoid will have thawed like I said earlier. Get some wd40 sprayed on it now and it shouldn't happen again Smile
Post #189668 29th Nov 2012 10:26pm
mk1collector
leeds wrote:
Going slightly OT
Brendan
I know it's a long shot but on the mrs polo you blip the fob once to open the drivers door and a second time to unlock both doors. Maybe if you blip the fob twice the rear door will unlock. I know it's a Landrover and unlikely but I thought worth a try maybe?
Ray
Post #189671 29th Nov 2012 10:30pm
