![]() | Home > Technical > Ignition feed for aftermarket alarm |
| Stoney Member Since: 28 Sep 2012 Location: Hampshire Posts: 87
Can any one help me with the ignition feed on the back of the ignition on a 300tdi, im a complete dummy when it come to electrics give me a spanner and welder any day !
it has 5 conectors 3 on the right and 2 on the left as you look at it from the back. I'm trying to fit a hawk alarm http://www.hawkcaralarm.com/DownloadManual...QUwg0.aspx this is the link for the user manual. On page 10 is a diagram and page 9 a description. the red and black are sorted, I think the white and yellow are as well ive put these to the top left hand spade and the middle right spade (from back) I believe these are both for acsessories and aircon if fitted but i haven't. So that just leaves the green and blue from the description they seem to be the same thing can any one tell me which they connect to. Thanks in advance jack |
Anyone got any ideas
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
The back of the ignition is fiddley to get to really but really the best location as it would also be fiddley for someone trying to steel it to remove it.
Pete |
| sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147
Is this on a tdi? ( looking at your gallery )
Yes it is, as long as it hasn't had the good old previous owner none standard modification due to not understanding what those odd looking bolts are for. Simple way to look at it, Big brown wire = ignition switch feed Big white = on when car is running Red/white = on only when you are starting the car I apologise if that comes across in a condascending manner, it wasn't intended to do. |
Edited due to my awful typing :No it didn't at all. That's great just what I was looking for, thamks for your help
