Fitted a pair of helper springs(as found on 130's) to my 110 as it was beginning to look a tadge tired on the back end and there is generally a load of junk in the back. It's lifted the back end by 50mm and now looks standard with the slightly higher back end, must remember at the next car park barrier
Sorry, double post, damn phone!
went to the flying club for a bonfire and fireworks, used the LED bar on the airfield - awesome
Guess you simply lit the bonfire with your LED bar from 30 meters distance, yes?
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
they actually used some spirits that are used to clean the gliders ... wooooooffff - even the fire doors burned thru eventually
Visited the dealer and made appointment for replacing my rear window for the new model window with the rerouted top three heating elements which hopefully won't get killed any more by the 3rd brake light. My 3rd rear window replacement, luckily still under warranty
LittleFoot Member Since: 25 Aug 2012 Location: east sussex Posts: 233 ![]() ![]() |
Today I fitted a lovely shiny snow cowl from MPS - good job Simon, to match my lovely new G4style rack!!! Happy days!
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
Cleaned the MAF sensor. The mid range acceleration seems much livelier now, even though larger tyres have raised the gearing.
Fitted my Sands and Buchanan seat covers.
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Popped out for a while and my plans changed so ended up doing about 100 miles around Kent and Sussex. What grim weather though, the Puma felt very safe and secure going through many small flooded roads where ordinary cars were not coping very well. BM52
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
How did you clean it? with some carb/brake cleaner? might try that on mine, and the MAP sensor too. |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Well I found some time and finally fitted the Puma load area with Noise Killer, then took it for a spin, definitely better. Can't hear the spay in the arches anymore.
![]() Puma Defender 90 |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Nice to hear(!) and reminded me I've still got the kit in the garage....bought in June ![]() Stu |
