![]() | Home > Tdi > what's up ? |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
this morning, I took it out for a run up the hill, temperature went just over 1/2 way and stayed there, stopped at the top of the hill and had a look under the bonnet. the bottom hose is hot, the top hose is cool, the expansion tank is warm.
tried the heater, works a treat, left it on and the temp dropped to 1/2 way (normal) my theory now is I have a blocked radiator or blocked bottom hose - thoughts anyone ? |
| Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582
Steve
As you've replaced a few things already might pay to replace expansion tank cap, even a slight leak will affect the cooling system. Wouldn't have thought your rad is blocked internally. 2007 TD5 90 Hard Top |
thanks Nige, but it's not using water, just not cooling it enough.
any idea what the small black connector does that joins the small radiator hose, the small thermostat hose to the expansion tank ? is it a one-way valve or just a connector ? |
One way valve, as fitted to vehicles with a later Webasto, or so I believe 2007 TD5 90 Hard Top
there not a webasto on the 300.
just read up about another 300 tdi with the same symptoms and it looks like the block may need flushing. the owner used central heating flushing liquid - I might give that a try |
ran central heating cleaner thru the engine for 2 hours and use high pressure water to flush it all out, some stuff with the consistency of egg-white / snot came out.
refilled with water and a/f mix ... better. then took out for a test drive, put lights on and gauge went up On advice from another forum, I am also going to put a new earth on the dash to the bulkhead. .. thanks for all your help .. 25th Nov is ON |
