![]() | Home > Puma (Tdci) > Towbar electrics |
I think its up behind the right hand rear light panel grey plug? under the wheel arch, there should be a matching plug. Original Member Pie n Pea Club.
110 HCPU Tipper |
http://www.defender2.net/forum/post1413.html Original Member Pie n Pea Club.
110 HCPU Tipper |
![]() Click image to enlarge The grey plug is concealed behind a plastic panel up in the rear RH wheel arch. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Anyone got any tips on pulling the dam thing apart!
4x4man Member Since: 02 Oct 2012 Location: staffordshire Posts: 51 ![]() ![]() ![]() |
Many thanks for your advice all. I will give it a go today .
There is a second wire with plug its little whiteish / clear plug ? Ray 2023 110 Xs commercial D250 2005 D3 HSE (green lane toy) 1983 westwood gazelle 11HP still going strong |
What colour is the wire?
Here is a photo of the cable showing the two plugs
https://www.icloud.com/photostream/#A1532ODWbW7Ik Regards Ray 2023 110 Xs commercial D250 2005 D3 HSE (green lane toy) 1983 westwood gazelle 11HP still going strong |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6199 ![]() ![]() ![]() |
Knowing britpart, it'll have a 13amp domestic 3 pin plug on it
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Have you got the 12N socket or the 13 pin socket. If the latter then I believe the white plug is power for fridge ! I would presume it would be plugged into the live socket found behind the OS rear speaker cover on my 2010 MY 90. I believe this socket may have been removed in th2013 MY Defenders
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
It's a standard 7 pin 12N 2023 110 Xs commercial D250
It's got a clip, or clips, that you squeeze at the same time as pulling the plug and socket apart. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
