Home > Puma (Tdci) > Towbar electrics
4x4man
United Kingdom 2012 Defender 110 Puma 2.2 CSW Orkney Grey
Towbar electrics
Hi
Can anyone help with some photos or info, to install the electrics. As I purchased a britpart towbar with plug and play electrics
But cannot find a plug in the motor.
I have looked behind both speakers and underneath.
Any ideas anyone for a my13 model ?
Regards
Ray 2023 110 Xs commercial D250
2005 D3 HSE (green lane toy)
1983 westwood gazelle 11HP still going strong
Post #183828 10th Nov 2012 8:23pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I think its up behind the right hand rear light panel grey plug? under the wheel arch, there should be a matching plug. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #183829 10th Nov 2012 8:25pm
willy eckerslike
http://www.defender2.net/forum/post1413.html Original Member Pie n Pea Club.
110 HCPU Tipper
Post #183833 10th Nov 2012 8:42pm
The grey plug is concealed behind a plastic panel up in the rear RH wheel arch. Darren
Post #183896 10th Nov 2012 11:45pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Anyone got any tips on pulling the dam thing apart! Confused
Post #183938 11th Nov 2012 9:47am
4x4man
Many thanks for your advice all. I will give it a go today .
There is a second wire with plug its little whiteish / clear plug ?
Post #183942 11th Nov 2012 9:56am
me@td5.org
What colour is the wire?
Post #183943 11th Nov 2012 9:57am
4x4man
Here is a photo of the cable showing the two plugs
https://www.icloud.com/photostream/#A1532ODWbW7Ik
Regards
Post #184007 11th Nov 2012 3:12pm
Knowing britpart, it'll have a 13amp domestic 3 pin plug on it Rolling with laughter
Post #184014 11th Nov 2012 3:59pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Have you got the 12N socket or the 13 pin socket. If the latter then I believe the white plug is power for fridge ! I would presume it would be plugged into the live socket found behind the OS rear speaker cover on my 2010 MY 90. I believe this socket may have been removed in th2013 MY Defenders Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #184089 11th Nov 2012 8:37pm
4x4man
It's a standard 7 pin 12N 2023 110 Xs commercial D250
Post #184100 11th Nov 2012 8:51pm
Happyoldgit
It's got a clip, or clips, that you squeeze at the same time as pulling the plug and socket apart. Steve.
http://forums.lr4x4.com
Post #184122 11th Nov 2012 9:18pm
