![]() | Home > Maintenance & Modifications > Help please - getting the air filter box off Puma |
I admit, if there was an "idiot" section, I would post this there
![]() Please can someone tell me how to take out the lower air filter housing. I can see rubber mounts but I can't see how it's fixed/bolted in. I've looked in the manual but there's just a sketch with some bolt heads that I can't identify ![]() Many thanks for any advice. Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
It appears to be a pain in the bum to remove, I looked at this last week when replacing the shocks (because the screw on the RHS turret cover is hidden by the airbox)...Can I ask why you want it off? Just in case you want access to the right-hand shock turret cover??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Little experiment - comparing how the intake air temperature varies when moving and stationary between taking air from the side intake and taking it from the engine compartment. Can only get the plastic intake pipe out with air filter box removed (I hope I can - it's bloody tight in there).
Unfortunately Scangauge takes its reading from the MAF and I would have liked it downstream of the intercooler but beggars and all that... Good to know it's how to get to the turret cover as well ![]() But shout it at them in German because life is also terrifying and confusing... |
Sounds like a fun project! It's worth relocating the turret cover screw whilst the airbox is off...just in case you want to change the Shocks in future, you won't need to worry about fighting with teh airbox again ![]() |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Thought I had a pic somewhere: ![]() Click image to enlarge From memory it's not something you'd take out for fun! Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Confidence ebbing again
