Home > Maintenance & Modifications > Help please - getting the air filter box off Puma
ZeDefender
I admit, if there was an "idiot" section, I would post this there Whistle
Please can someone tell me how to take out the lower air filter housing. I can see rubber mounts but I can't see how it's fixed/bolted in. I've looked in the manual but there's just a sketch with some bolt heads that I can't identify Embarassed
Many thanks for any advice.
Matt Tell someone you love them today because life is short.
Post #182848 7th Nov 2012 1:36pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
It's bolted through the wheel arch the heads are on the inside at the front about 4 or 5 I think
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #182849 7th Nov 2012 1:40pm
ZeDefender
Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh Embarassed
Bow down Tell someone you love them today because life is short.
Post #182851 7th Nov 2012 1:41pm
MartinK
It appears to be a pain in the bum to remove, I looked at this last week when replacing the shocks (because the screw on the RHS turret cover is hidden by the airbox)...Can I ask why you want it off? Just in case you want access to the right-hand shock turret cover??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #182864 7th Nov 2012 2:18pm
ZeDefender
Little experiment - comparing how the intake air temperature varies when moving and stationary between taking air from the side intake and taking it from the engine compartment. Can only get the plastic intake pipe out with air filter box removed (I hope I can - it's bloody tight in there).
Unfortunately Scangauge takes its reading from the MAF and I would have liked it downstream of the intercooler but beggars and all that...
Good to know it's how to get to the turret cover as well Wink Tell someone you love them today because life is short.
Post #182866 7th Nov 2012 2:28pm
MartinK
Sounds like a fun project!
It's worth relocating the turret cover screw whilst the airbox is off...just in case you want to change the Shocks in future, you won't need to worry about fighting with teh airbox again Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #182868 7th Nov 2012 2:31pm
ZeDefender
Thumbs Up Tell someone you love them today because life is short.
Post #182869 7th Nov 2012 2:34pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Thought I had a pic somewhere:
From memory it's not something you'd take out for fun!
Post #182899 7th Nov 2012 5:01pm
ZeDefender
Confidence ebbing again Sad Tell someone you love them today because life is short.
Post #182910 7th Nov 2012 5:25pm
