Home > Puma (Tdci) > Driving Light Wiring Loom
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I've got some Cibie Oscar+ lamps to mount on my A-Bar and need to wire them up safely.
A search on the site throws up a load of different solutions. At the minute they've got offroad 150W bulbs in, so my question is - is the Genuine kit beefy enough for this current draw or do I need to build my own wiring kit?
I'd like to keep things looking as neat as possible and a look under the bonnet doesn't exactly offer a load of options to mount relays or tap into wiring.
Oh yes and �90 odd seems a bit steep for a few wires from the dealer.
Post #18039 9th Nov 2009 3:14pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
The thing to remember is Watts = volts x amps
Therefore amps = watts/volts
And volts = watts/amps
So standard lamps would be 55w so at 12 volts thats 4.58 amps for a single light (55/12 = 4.58 ).
A 150w bulb would potentially draw 12.5 amps (150/12 = 12.5) so I'd go down the route of customised wiring.
Wire a suitable cable to take those amps from battery (via suitable fuse) to switched pole on relay, then from the opposite switched pole to the lamp. You will also need an earth wire from the lamp to a suitable earting point.
Then a wire from highbeam wire (need not be so beefy as it only takes "standard" current) to switch, from switch to relay then from relay to earth.
Here's a rough sketch of the wiring:
 MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #18059 9th Nov 2009 11:14pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
anyone found out where i can get a genuine wiring kit? LR don't sell it seperatly
Post #18104 10th Nov 2009 7:32pm
A few on ebay<-----
Post #18109 10th Nov 2009 8:53pm
nicks
i've seen those and they are charging a lot for a bit of wire and terminals. i'm looking for the proper kit, switch, loom - -plug and play kit that comes with the full light kit.
Post #18129 10th Nov 2009 11:13pm
Mad Cow
Only available as a complete kit with the lights I think. MAD COW
Project90
Post #18132 10th Nov 2009 11:26pm
mse
You can buy them from a dealer - they need to look under TD5 i recall Mike
Post #18172 11th Nov 2009 6:21pm
Correcto! part # STC8813AA �54.25 (it's listed under German spec front spots, and probably a couple more listings too, but that's the first one I found) Thumbs Up
Post #18186 11th Nov 2009 9:33pm
TJ101
Yep, TD5 loom in mine,,
Power and earth (via relay and fuse) out from the battery box, ran underneath and up the bulkhead, branch off into cab, to a Gen dash switch, and another over to the dash to pick up the headlamp beam wire (Blue/white from memory)
The other branch runs forwards to the lamps,,
Not hard to make your own California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #18187 11th Nov 2009 9:38pm
mse
I made my own - the main difference on the TD5 to puma is the recommended path for the wires Mike
Post #18198 11th Nov 2009 11:32pm
nicks
but does that kit come with the switch and correct plugs, STC8813AA was pre Td5 Defender & Discovery Tdi. A mechanic at the dealer said the wiring kit for the TD5 is completly different to the wiring kit that is now fitted on the puma.
MSE - did you mange to wire in the proper dash switch?
Post #18211 12th Nov 2009 8:51am
mse
Yes and with the correct connector, im not a fan of bodged on stuff
As for wiring kit - there were some minor changes - but nothing major in the TD5 to Puma Mike
Post #18238 12th Nov 2009 5:55pm
nicks
where did you get the switch and plugs from - (hope you don't mind me asking, i'm the same as you hate bodging wires etc)
Post #18240 12th Nov 2009 6:01pm
mse
Switch from the dealers and the connector from a local company who i asked.
THere is a detailed thread on here somewhere. Mike
Post #18244 12th Nov 2009 7:41pm
Mad Cow
That would be this one: http://www.defender2.net/forum/topic552.html?highlight=tyco MAD COW
Project90
Post #18262 12th Nov 2009 10:58pm
