![]() | Home > Puma (Tdci) > Driving Light Wiring Loom |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
The thing to remember is Watts = volts x amps
Therefore amps = watts/volts And volts = watts/amps So standard lamps would be 55w so at 12 volts thats 4.58 amps for a single light (55/12 = 4.58 ). A 150w bulb would potentially draw 12.5 amps (150/12 = 12.5) so I'd go down the route of customised wiring. Wire a suitable cable to take those amps from battery (via suitable fuse) to switched pole on relay, then from the opposite switched pole to the lamp. You will also need an earth wire from the lamp to a suitable earting point. Then a wire from highbeam wire (need not be so beefy as it only takes "standard" current) to switch, from switch to relay then from relay to earth. Here's a rough sketch of the wiring: ![]() Click image to enlarge MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
anyone found out where i can get a genuine wiring kit? LR don't sell it seperatly
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6188 ![]() ![]() ![]() |
A few on ebay<----- |
i've seen those and they are charging a lot for a bit of wire and terminals. i'm looking for the proper kit, switch, loom - -plug and play kit that comes with the full light kit.
Only available as a complete kit with the lights I think. MAD COW
mse Member Since: 06 Apr 2008 Location: UK Posts: 5103 ![]() ![]() ![]() |
You can buy them from a dealer - they need to look under TD5 i recall Mike
Correcto! part # STC8813AA £54.25 (it's listed under German spec front spots, and probably a couple more listings too, but that's the first one I found) ![]() ![]() Click image to enlarge |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Yep, TD5 loom in mine,,
Power and earth (via relay and fuse) out from the battery box, ran underneath and up the bulkhead, branch off into cab, to a Gen dash switch, and another over to the dash to pick up the headlamp beam wire (Blue/white from memory) The other branch runs forwards to the lamps,, Not hard to make your own California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
I made my own - the main difference on the TD5 to puma is the recommended path for the wires Mike
but does that kit come with the switch and correct plugs, STC8813AA was pre Td5 Defender & Discovery Tdi. A mechanic at the dealer said the wiring kit for the TD5 is completly different to the wiring kit that is now fitted on the puma.
MSE - did you mange to wire in the proper dash switch? |
Yes and with the correct connector, im not a fan of bodged on stuff As for wiring kit - there were some minor changes - but nothing major in the TD5 to Puma Mike |
where did you get the switch and plugs from - (hope you don't mind me asking, i'm the same as you hate bodging wires etc)
Switch from the dealers and the connector from a local company who i asked.
THere is a detailed thread on here somewhere. Mike |
That would be this one: http://www.defender2.net/forum/topic552.html?highlight=tyco MAD COW
