![]() | Home > Tdi > Water ingress cure??? |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
Im sure i've seen posts on here where masking tape is placed either side of the seal, run a bead of sikaflex and then smooth out by running a finger down it.
I'll try and find it. |
Found it here
Found it here
peterl Member Since: 08 Jan 2009 Location: Pembrokeshire Posts: 307 ![]() ![]() |
Thanks for this, will get the job done when the weather clears up
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
What colour did you use? Clear?
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 500 ![]() |
Your better off using roof & gutter sealant. It remains more flexible.
Used it on mine. Can be used in wet conditions Martin ![]() |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 657 ![]() ![]() |
It's a foam strip, so after a while it compresses and doesn't seal as well. A good new seal fitted ok with stay watertight for at least 5 years, but as has been suggested you can make sure by adding some sealant too.
