Home > Maintenance & Modifications > wheel arches on a 90
geoff.
Hi All
i,m running 265,s and spacers on a 2010 defender 90 and at a game shoot over the weekend car got covered does anybody know if you can get wider arch kits and are they any good Thumbs Up
Post #180283 30th Oct 2012 10:31am
leeds
To be 100% road legal the tread of your tyre should be within a vertical line dropped from the wheel arch. Side walls can be protrude outside vertical line. Can not remember if that comes under C & U or what legislation but is not an MOT issue.
Wider arches can be bought from Barry at Flatdog, have a look HERE
That will not completely cur the problem however. You might also want to consider the Entreq Mudflap extensions which we stock. details can be found HERE These extend the front mudflaps 50mm outwards.
HTH
Brendan
Post #180314 30th Oct 2012 11:53am
farmer giles
whats wrong with a muddy land rover Cool
i happily run 235 bfg all terrains (without spacers) and i have never got stuck at a shoot in 20 years
a driver training day with LRExperience maybe cheaper than wheel arch extensions or a fine as Leeds highlights
Thumbs Up
Post #180319 30th Oct 2012 12:06pm
Re: wheel arches on a 90
geoff. wrote:
Hi All
I run this set-up on my 110 and the biggest problem is the gap between the bottom of the arch and the top of the mud-flap. I'm not sure that wider arches would solve it, to be honest, as the tyre is under the existing ones.
For illustration purposes only, before anybody comments - I know it's not that muddy:
It's on my list of things to do to make up an infill between the two from some rubber sheet when I get chance. Darren
Post #180330 30th Oct 2012 12:30pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Mine with 285's is the same. Wish someone would come up with a bolt -on solution that looks good.
Post #180334 30th Oct 2012 12:42pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
LandRoverAnorak wrote:
geoff. wrote:
Hi All
See my post here : http://www.defender2.net/forum/topic14443.html Thumbs Up
Alex 110 Tdci Double Cab
Post #180347 30th Oct 2012 1:24pm
That's the kind of thing, although I'd prefer it made out of something flexible. Darren
Post #180362 30th Oct 2012 2:08pm
The Boy
I would like to see a mini moulded rubber mud flap.
Post #180365 30th Oct 2012 2:18pm
geoff.
giles
never said i got stuck Whistle
Post #180367 30th Oct 2012 2:22pm
bob neville
Brendan, sorry to say the Entreq mud flap extension brackets do very little to help in this situation if you have a non standard offset wheel fitted (or spacers) - as you know I do have a set fitted on my 110.
The problem is the taper at the bottom of the eye brow and the gap between the wheel and the mudflap - this allows an unrestricted path for the mud and dirt to cover the side of the vehicle.
The only way to resolve the issue is to fabricate something to fit into the gap, Markb110 has used rubber from an old mudflap to make an extra flap that stops the problem. Easy to do if you have rock sliders fitted as they give a convenient fixing point.
The Entreq MF extension is excellent and a worth while addition but, unfortunately, they don't help that much with the problem if you have a different offset wheels or spacers.
2013 Defender 90 CSW - sold
Post #180445 30th Oct 2012 7:18pm
farmer giles
geoff. wrote:
giles
sorry Embarassed
i was in a pants mood after driving a C1 back from the dealers Evil or Very Mad
Southdown did a rockslider that had a rubber section at each end that met with the spats to provide a bit more cover in that area; trouble is you can't get them anymore.
i'm not helping much, am i?
Post #180567 31st Oct 2012 9:44am
aage
Iceland 2011 Defender 110 Puma 2.4 DCPU Alpine White
This is what I did
My puma is on a 285 75 16. And to prevent it to get all muddy , I installed these Sidesteps , then connected it to the Fender Flares with a piece of aluminum ( it forces the lower side of the flares out to make it as wide at the bottom as it is at the top ) so now it covers the width of the tires.
It works very good and not it don't dirty itself as it used to do.
You can see how it looks on this photo ( the cartoons and the red colors are PHOTOSHOP Wink. )
http://www.defender2.com/forum/topic15816.html
I can take a closup photos of this later if you like and post it on my gallery. http://www.defender2.net/gallery/index.php?cat=13451
Post #180576 31st Oct 2012 10:23am
aage
Again
just posted this topic.
Photos ,,, http://www.defender2.net/gallery/index.php?cat=13451
Post #180599 31st Oct 2012 11:57am
aage
UBS
Post #180600 31st Oct 2012 11:58am
