![]() | Home > Maintenance & Modifications > Broader wheels, broader mud guard sizes for a XS |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
I fabricated a small section of plate that prevents the fling up. I'll post a pic tomorrow.
Alex 110 Tdci Double Cab |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
Thanks, much appreciated.
Entreq does extended mud flap brackets. I had exactly the same issue and they cured it.
![]() http://www.defender2.net/forum/topic5108.html?highlight=entreq If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Any pictures of how far your tires extend out of your arches?
What wheels do you have on and what offset do they have (or are they LR wheels with wider tires? You are legaly allowed to have the tires stick out a little. It is the tread pattern that matters the most. My BFGs stick out a little but the tread is in-lin/ just inside the arches. As above for mud-flap ideas ![]() Glyn ![]() ![]() |
![]() Click image to enlarge Untitled by .:ay4alex:., on Flickr ![]() Click image to enlarge Untitled by .:ay4alex:., on Flickr ![]() Click image to enlarge Untitled by .:ay4alex:., on Flickr ![]() Click image to enlarge Untitled by .:ay4alex:., on Flickr 110 Tdci Double Cab |
Dropping a vertical line from the wheel arch/flare the tread of the tyre must be inside that line. The side wall of the tyre can be outside of that line.
We stock the Entreq Mud flap extension brackets. XS Pete has done a decent write up here here ![]() Brendan |
It can be a 'grey area' as the arches are 'wasted' and whilst you may not fall foul of the rule above at the 12 o' clock arch position the tryres protrude further and further round the arch you go. Anyone got the definitive answer? Not had any issues myself MOT time but think it may depend on the tester's interpretation. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
IIRC Fekete has some neat eyebrow extensions on his, so you retain the original body-coloured eyebrow and then add a small extension piece to its outside edge. I certainly remember seeing some on here somewhere, and think it was Fekete's 90. Don't know if he sourced them somewhere or made his own. May be worth a PM. 2005 Td5 | 90 Station Wagon | Tonga Green
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
The ones i used was the pacer fender flares...i got mine from Canada but you can get them on line in different sizes here are the ones i have
http://www.amazon.com/Pacer-Performance-52...sbs_auto_5 Here you go on how to fit ![]() http://www.defender2.net/forum/topic5309.html?highlight=pacer NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
There you go! Memory served on that one!
