Home > Puma (Tdci) > Survey - Negative effects after a Puma TDCi is mapped?
Page 2 of 2 <12
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
BruceT wrote:
Naks wrote:
pannawonica wrote:
Extra noise maybe due to increased injector pressure, mine did the same. However @ coke full of 2SO per tank the engine is quieter and smoother pre remap. Thumbs Up
Yep, there is a bit of extra noise, but that's normal. 2SO definitely quietens things down
Ive never used 2SO. Please send me the details of what you use.
Thx Naks.
Ai, ai, ai........ Whistle
ONLY USE SASOL 2so FC grade!
I've been running +_250ml/tank for the last year. Thumbs Up
Post #180543 31st Oct 2012 7:12am
BruceT
South Africa
Thanks Regard.
Do I just add the bottle to the tank when I fill up? (i have a 120 litre tank)
Post #180544 31st Oct 2012 7:18am
Regard
Yes Bruce
In your case one bottle (500ml) per tank. (+_ 1:200 mix)
Dump it in there just before they fill up.
I also have a 100l tank (extra tank) so I just split mine 50% in the main tank and 50% in longrange tank.
Thumbs Up
Post #180545 31st Oct 2012 7:22am
BruceT
South Africa
Thanks Regard.
So thats the only negative effects that have been experienced?
Post #180546 31st Oct 2012 7:25am
Regard
Just to clarify....
I've never heard a change in my engine noise? Well...I've been using 2so even before the remap but infact, I think the engine runs even more smooth after the remap!
Post #180547 31st Oct 2012 7:32am
Naks
Bruce, I just chuck in a bottle (200ml) of the Sasol 2SO when I fill up there. --
Post #180556 31st Oct 2012 8:11am
BruceT
South Africa
ok thanks....will try with my next tank full.
Post #180558 31st Oct 2012 8:19am
GREENPUMA
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
Have an '07 110 with Alive 'light' re-map. It made a big difference to torque profile. Pulled easily in 6th from 40mph instead of 50mph. Then fitted a S/S de-catted 3"diameter sports exhaust system with only a very small silencer at the back, and now transformed the vehicle again. Very much smoother, quieter, apart from the bark at the back when pulling hard. Slight drop in mpg, but that might be the driving-style since fitting the exhaust Embarassed
Post #193558 14th Dec 2012 8:33pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
overall re-map great and pulls hard from low down......only small thing so far is occasional hiccup when coming from over-run and back onto the throttle or when changing up through the gears. Hardly noticable so it is no real problem. the rest is all positive
Post #193753 15th Dec 2012 5:14pm
ClaireWright
United Kingdom 2008 Defender 90 Puma 2.4 HT Keswick Green
My map is fine
Post #193777 15th Dec 2012 6:25pm
Page 2 of 2 <12
